Question about Gbc Combbind C110E Electric Binding System
GBC combbinder c110e is not consistently punching holes on page bottom
Not punching holes at the bottom of the page.
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
I have an Ibico ibimaster 400e Binder which is not punching out the holes correctly.
First, clear the waste tray of all hole punchings under the machine, and check the holes where the punchings feed from for any blockages. The worst thing is the clear plastic pages you use for covers, these can block up the holes. So you may need to pick them out of the holes using tweezers.
Then try again. If you have to punch clear covers, then try to do them with just a few pages on both sides so that the plastic sheet isn't the first thing the blades hit.
May 23, 2011 | Office Equipment & Supplies
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
CombBind C450e binding machine. How did I get the top off? A piece fell off inside and I cannot get the top off.
the top is connected with 7 star shaped screws look in the back of the machine you will see the exact shape. in the back there are 3 screws then there are 2 more screws on every side under the dark grey lable on is located on the very bottom (lift the lable you will find it) to find the other 2 slide your finger on the grey lable you will feel a small round hole on the right side it is about a cm under the **** where the papers get punched and on the left side it is about 3 - 4 inches under that ****. Good luck
Aug 27, 2010 | Ricoh FAX3900L Plain Paper Laser
The machaine jammed and now will not work. i have taken it apart and removed all of the jammed material. when the machaine is turned on, it goes stright into paper jam mode. There is an electric humming...
the machine still thinks it is jammed. the humming is probably the motor trying to turn, it can not beause it still has a jam? . you may need to remove the power cord from the wall. remove the shredder fro the stand. flip it over. remove the bottom cover and manual trun the cutting heads to unstick them. you may need a tech
Oct 21, 2009 | Office Equipment & Supplies
Are we able to get the Binding machine blades sharpened. We have an Ibico, Ibimatic-No 315468. Have had for about 5 years. Thanks
This product is now manufactured by GBC (General Binding Corp, part of Acco) and was replaced by the CombBind C150 - just FYI. The lower-end machines such as this seem to run in the range of $200 USD.
I have never heard of sharpening these "blades", as they are actually punches, and there are likely some 20 small, individual "blades" that are part of the system. You might check with a local dealer or office supply partner, to see if they know of anyone who could or would perform the service and what they might charge for it. I believe that if you could find someone to do it, it would cost more than it would to simply replace the machine. There does not appear to be a way to replace the punch mechanism (die / strip usually) in these models.
An example of a machine with interchangeable dies is located at: http://www.factory-express.com/Binding_Machines/WireBindingMachines/GBC-TL2900/GBC-wirebind-TL2900.html.
Obviously, this is a much higher-level (expensive) machine than the one you have here. But this is an example of the interchange concept, and associated costs.
So, this is a rather long way of saying, and trying to explain why I recommend that, you check with a local dealer perhaps, but plan to replace the machine. If it lasted you this long, the same level of machine should last just as well, and $40 US a year isn't too bad!
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 29, 2008 | Office Equipment & Supplies
Gbc Combbind C110E Electric Binding System Logo
56 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
