Question about Maytag Atlantis MAV6000 Top Load Washer
Washer transmission & brake bad - replace or not?
My Maytag Atlantis top load washer model MAV8551AWW has the bottom seal leaking on the transmission. The parts are covered under warranty, labor is not. Plus this has made the brake start to go bad too. Repair is $230.
What is a recommend replacement machine for long life and quality offering different cycle options?
  • 1,122 Answers
Kenmore elite washer,but first if you want to try to fix it yourselt look on ebay,put make and model number and see what comes up,i got a new transmission for $70 took my time taking apart then reassemble and it was pretty easy,let me know how you do-mike
Posted on Oct 23, 2008
Leaking from bottom
Sounds like the tub seal. My MAV2755AWW (Maytag Atlantis top loader) is doing the same thing right now. Here is the solution I found:
Caution: You'll need some tools, like a spanner wrench for your model...order this now of you plan to do this work yourself. You can find it for 15 dollars online, but if you go to Maytag, it can cost you upward of 90 dollars. You can get a tub seal kit for about 60 dollars. The cost for a repair tech to do this job was almost $300...gauge the $75 you going to spend plus the hours of work if you don't know what you're doing, against this cost. Good luck!
Jan 13, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Sudsy water is leaking from the machine
Hello there and thank you for choosing fixya
The tub seal is the most common thing that causes Maytag washers to leak. This is unfortunate because the tub seal is an expensive repair job and not one I would suggest doing yourself. I say this because it is complicated and requires special tools to perform this job. To check if the tub seal is bad, first remove the front panel by removing the two screws from the bottom of the front panel. If you have a newer model, prize the bottom clips with a screwdriver. Then pull the bottom of the panel until the top clips release. Then start the washer and watch for a leak around transmission where it goes through the tub. If it does leak then the tub seal is bad and needs replacing. If you have the tool or willing to buy it click here for instructions on how to replace the tub seal. If the tub seal doesn't, leak you probably found the leak while performing this test.
Mar 07, 2011 | Maytag MAH6700AWW Neptune Front-Load...
Leaking water out the bottom.
where in the bottom? could be a simple tub to pump hose or is it coming from the tub seal around the transmission.
Feb 19, 2011 | Maytag Atlantis MAV7551 Top Load Washer
Leaking drum on maytag washer.
Go to and enter MAV6000. With luck, you will be presented with a list of common replacement parts and may be able to view a generic Maytag video showing disassembly and replacement.
May 23, 2017 | Maytag Atlantis MAV6000 Top Load Washer
Wont spin
Sounds like the transmission seal had failed sometime back and has leaked the lubricant causing the transmission to overheat and now possibly seizing the gears, if this is the case the transmission will have to be replaced. Depending on the age of the washer, (5 years or less) you should contact Maytag to see if they will compensate you by way of furnishing the new transmission for free, but you will be responseable for the labor charge from a tech to do the replacement.
If they will not cover the part, you will probably be better off to replace the washer than to invest in the cost of a new trans and labor.
Good Luck !
Mar 21, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My washer makes a grinding noise when agitating. all other cyces work ok
It sounds like you have either a bad bearing or more likely the transmission is going. Look to see if you have any oil leaking out of the transmission. If so, see if you can replace the seal that is leaking before the transmission goes completely. Good luck.
Mar 07, 2010 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MAV8551aww, loud grinding noise during spin cycle.
Yes. Junk It. Problems that cannot be fixed and customer service stinks
Oct 24, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Leaky Maytag
most likely. the tub seal is bad. mine did the same thing. had to replace the seal. part is called a triple lip seal. not hard but not a walk in the park either.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Maytag atlatis mav8551aww washer runs fine til spin mode then
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Apr 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Heavy water leak during when washing clothes
disconnect the hose on the bottom and see if the seal is good.If it is good, then remove the back panel, start the washer and watch and see what seal is broke and you can visually see the exact spot the water is leaking from.
Feb 04, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
422 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
