Question about Kyocera Finecam S4 Digital Camera
Camera seems to have frozen
The camera is 'on' the lens is extended and the flash is in the up postion. Nothing happens when the shutter button is pressed and when the Power button is pressed to switch off the LCD shows the following message Error C1 The battery sign shows fully charged. Any ideas please would be appreciated. Jessops have quoted £200 just to look at it
  • dorianma Aug 24, 2008
    C1 message
3 Suggested Answers
  • 883 Answers
SOURCE: Non-functioning camera
open the unit. look for anything electrical disconnected from sloppy factory
Posted on May 21, 2007
  • 422 Answers
SOURCE: At the "battery empty" sign
long shot:
remove battery
press and hold down the power button,
insert battery
Posted on Jun 12, 2011
Camera not working
Hi Jane,
When we press the shutter release the mirror flips up after the shutter opens and closes the mirror flips down. When it flips down we then see out the viewfinder.
At first blush is sounds as though the mirror flipped up but not back down. Remove the lens look inside the camera press the shutter release what happens?
Cordially,
Jul 25, 2013 | Canon EOS Rebel 2000 35mm SLR Camera
Kodak m522 turns off with lens extended
Here are some troubleshooting steps that you can try:
Dec 09, 2012 | Kodak M522 Digital Camera
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
Have a samsung camera that seems to be frozen. The lens is open but there is nothing on the screen. When pushing the power button the power light flashes, the camera makes a beep and the the power light...
Hi, this happened to my Samsung ST500, it took me months to find out what was wrong with it!, i found out the it gets stuck when the lens is different or has dirt in the lens.
  • I Got Mine working by cleaning the lens but if that dosnt work try this, mine started working when i dropped my camera quite high onto the ground which can make your lens pop back in if this dosnt work, try your warranty!:)
Oct 24, 2010 | Samsung DualView TL220 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
D80 "battery drained' and "F"sign when pressing release button
Pls make sure of the following:
- You are using original Nikon batteries (generic batteries gave a similar problem to me)
- The aperture ring of your camera is correctly placed
Nov 16, 2009 | Nikon D80 Digital Camera with 18-135mm...
Transferred the pictures from the memory card onto the computer and put card back in. Tried to turn it on, but now the lens is stuck, it didn't open fully, and I need help. It seems to have frozen while...
This would need to be repaired if the lens is stuck so is the shutter. I would take it in and have it looked at. there is no other resetting then what you already have done ot the unit.
thanks for rating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Sony Cyber-shot DSC-S650 Digital Camera
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
Casio Exilim Z40 - Lens Error Message
You can try to "fix" this problem by holding down the shutter release button as soon as the camera power up.If this does not work you will need to replace the lens assembly. This should only be done by a qualified tech.
This is usually caused by one of two circumstances. (1) The user dropped the camera while the lens was extended causing a mechanical failure. (2) The lens attempts to extend while in a pouch or pocket without the user's knowledge. This usually happens when the user is carrying the camera with the battery in. When/if the REC button or power button is pressed accidentally, the lens will attempt to extend but can't. This causes the servo motors to "smoke".
Apr 25, 2009 | Casio Exilim EX-Z40 Digital Camera
NO LCD IMAGE / LENS STUCK
hi ban ive same problem bloody nusience lens wont retract what did u do with urs?
should i return it?
thanks leeanne
leeannehutchinson@btinternet.com
Feb 17, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Kyocera Finecam S4 Digital Camera Logo
44 people viewed this question
Top Kyocera Cameras Experts
Harrie
Tony Parsons
Tony Parsons
Are you a Kyocera Camera Expert? Answer questions, earn points and help others
