Question about Garden
Pioneer p38 chainsaw has no spark - Garden
2 Suggested Answers
  • 113 Answers
SOURCE: have an old pioneer p38
You need to disassemble the carburetor and check the diaphragm. You need to blow nozzle of carburetor. If the fuel was left in him, now it has remaining traces of oil. You can try to start with a small pump to inject fuel directly into the intake of the air into the carburetor. Of course, the spark has to be here to start. Older chainsaws had a switch and a capacitor, which is very difficult to adjust. Newer chainsaws have electronic ignition, so it is easier for test. Most of carburator has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed. Good luck!
Posted on Sep 06, 2011
Have an old pioneer p38 chainsaw, belongs to the old man. hasn't been started for a few years. replaced fuel gave it a clean thats all, wont go.
Sep 06, 2011 | Garden
My MTD 3161 chainsaw starts fine and then dies after several minutes
hello
after it warms up and then dies check to see if it still will generate spark. my hunch is once the coil heats up it stops working.. I had a pioneer do this to me.
hope this helps
Dennis
Jun 12, 2011 | Garden
1998 p38 at 2000 rpm's it bucks wont go over 30 miles an hour.swapped air mass,coils r/r spark plugs fuel filter fuel pressure at 35psi.
hi i have just had he same problem with my V8 p38 try cheaking your crank shaft senser we have just taken ours out and cleaned it up with carb cleaner and it works fine
Oct 19, 2010 | 1998 Land Rover Range Rover
RANGE ROVER P38, PARKED UP NO PROBLEM , NEXT MORNING TURNS OVER WITH NO SPARK AND NO FUEL??CAN ANYONE HELP
This also happened to my P38, parked at night ok and next morning nothing.
I had a BBS faultmate which when connected told me that 'the engine ecu had not received the code from the BeCu in the specified time'.
I'd had enough by this time and sold the car and the new owner send both these ecus away to get reprogrammed (at a cost).
This may or may not be your problem, it could be an immobiliser fault but being a P38 (loved mine by the way despite all it's foilbles!!) it could be any one of a number of things.
Really without diagnostics your p***ing into the wind with a lot of the faults in a P38 I'm sorry to say.
Sorry not to be more of a help and good luck with it.
Iain
Oct 04, 2009 | Land Rover Range Rover Cars & Trucks
Drivers for hcl notebook p38 pdc
how can i get lan driver for hcl notebook p38 pdc
Sep 19, 2009 | Computers & Internet
Car not starting
Yes without the cam signal it doesn't know just when to fire the respective spark plugs
Sep 13, 2009 | 1996 Land Rover Range Rover
Spark plug for mcculloch 2014 2.0ci and what is oil to gas mix
Not sure about the spark plug but the mix:
Any quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 years ± 50:1 (Stihl 2.6oz/1gal)
Today most gas in the US of A contains ethanol; not good with chainsaws. mix what expect to use within a few months. Anything over 6 months use up in a 4 cycle engine. HTH
Lou
Sep 10, 2009 | McCulloch Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
