Need boston wk1201a5-1an ac power supply charger adapter for speakers
Hard to find
    Novelist:
  • 184 Answers
3 Suggested Answers
SOURCE: Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Posted on Jul 16, 2009
SOURCE: No power to my subwoffer
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
I am looking for a power cord for JBL on stage II speakers. Part no. 700-0042-001. Model no.TEAD-48-180800U
The following power cords will work with your speakers
You can purchase the power cord from the following site if you are in the UK:
http://www.power-adapters.co.uk/jbl-7000042001-acdc-18v-power-supply-adapter-p-7165.html
You can purchase the power cord from eBay if you are in the US:
http://cgi.ebay.com/AC-Power-Supply-Adapter-Charger-JBL-700-0042-001-/350422898000
Regards,
sjstore2
Dec 18, 2010 | JBL CREATURE II Computer Speakers
I lost the ac adapter. where can i buy one for this model 400 amps 260 psi air comp
Hello, I found that a 12 volt, 1500 milliamp charger for a Boston Acoustics set of speakers works to charge this. (halfway charged, today). So, I 'm sure on the 12 volts, and hoping it will be enough power to fully charge. B
Aug 15, 2010 | JUMP START SYSTEM
I don't have the AC DC 12V in (power cord). What kind is it?
Not only do you need the correct voltage and amperage (MAH) but you need the corectly sized plug to fit the socket AND it has to be in the correct polarity. Usually the polarity is marked by a broken circle with a dot in the middle. Leading to this dot will be an arrow or just a line and at the other end of the line will be either A positive (+) or negative(-) It's important you get this polarity correct when plugging a new power supply in.
Your local electrical store should be able to sell you either a fixed 12volt supply or even a variable supply allowing 3, 6, 9 or 13 volts output. Make sure it has the amperage capacity you need. It won't matter if you need 500Mah and the supply is 750Mah as long as it isn't less than what you need.
The power supply should come with an assortment of plugs which are insrted into the socket on the end of the power supplies lead. Follow the instructions on the packaging and ensure you have the center pin set as either + or -. If you are in doubt. Take your speaker which has the socket fitted and show the salesman. He should be able to pick the correct plug and make sure it's the right way around.
If you plug it in and nothing lights up, quickly remove the plug and turn it 180 degrees in the power lead socket. Obviously it's been put in the wrong way round. If you were quick enough no damage should have occured and away you go.
Just one tip. Wrap a small piece of insulation tape around the plug to stop it from being pulled out of the power lead's socket. They do tend to work loose after a while. Oh and make sure it's switched to 12 volts if you get the variable one.
Apr 25, 2010 | Boston Acoustics BA65 Computer Speakers
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Feb 09, 2009 | Boston Acoustics BA7500 Computer Speakers
Background hum
I fixed the same issue by replacing the original AC power supply with a 13.8 volt DC power supply (Radio Shack) It seems to be more consistent at high SPL and no hum , as the Boston acoustic unit accepts either AC or DC power.
Jan 29, 2009 | Boston Acoustics MediaTheater Computer...
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
POWER SUPPLY
Hi, the mA rating for this power adapter is 1500 mA !! I'm gonna give you all the specs. you need to order a new one, and I'm gonna tell you where you can order a new one at; at your preference ?
POWER SUPPLY/POWER ADAPTER TRANSFORMER FOR:(WALL PLUG IN)
BOSTON ACOUSTICS MICROMEDIA SYSTEM 7000596
2.1 SURROUND (2 SATELLITES) (1 SUBWOOFER)
MODEL # WK1201A5-1 AN (THIS IS THE MODEL # FOR THE PLUG)
I/P(INPUT) 120 VAC 60 HZ / 23 VA
O/P(OUTPUT) 12 VAC 1500 Ma
This is all the info you need to order a brand new one in the box.
Go to www.emtcompany.com and in your search box punch in the model # wk1201a5-1an. they cost 29.99 new but its worth it for a great sound system. good luck and I hope I helped a bit
steve - if you have any further questions, i will be glad to help out, you can email me bostonrox129@yahoo.com
Aug 28, 2008 | Boston Acoustics MicroMedia Computer...
Boston Acpustics BA745
you cannot plug the phono jack directly into the motherboard, there needs to be another piece that you can add, it has a yellow speaker sticker that you install into the computer, onto the motherboard. it is not an add-on card, but an accessory you can buy. this is because the speakers are self-powered, meaning that they need power from the motherboard instead of an AC adapter
Nov 17, 2006 | Boston Acoustics BA745 Computer Speakers
 Grubhead
Grubhead
