Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light Here ya go. I have a 170t reddy Heater and have used it quite a bit this winter. The other day it blew a fuse and I replaced it with the correct fuse. Now it will not light and the ignitor indiactor light comes on....so needing a heater I also have a 125t I used it very little this winter but I used it the other day and it ran off an on all day. The following day it would not light. However the fuse is fine in this unit but I am getting the ignitor indicating light again. Any Idea what is happening? Also burning a mixture of off road deisel and #2 fuel oil Same problem on Reddy Heater model 125T. I can plug it in, power comes on, but when i turn up the thermostat the ignitor light flashes and the heater does nothing. I have ran a test on the ignitor and it shows 44.8 ohms. Fuse is good. I have cleaned the nozzle and checked all hoses. Any ideas?
  • givme5 Dec 05, 2008
    therostat don't work
Thermostat don't work on my 125T unless you turn it up to about 55 even though it is colder in the garage
Posted on Dec 05, 2008
  • 232 Answers
Are the ignitors intact? In other words, does the element make a loop back to the ceramic portion. The purpose of the LED is to notify the user of a defective ignitor. The other possibility is a bad control board.
If the ignitor is intact, but no power coming from the board (ignitor only glows for 5 seconds), then the board is bad or the fuse is blown. You might want to test the photocell while you are at it.
You will need to locate the correct model numbers to order the correct parts. "170T" & "125T" are only part of the correct model designation.
Post back if you have further questions.
Posted on Oct 23, 2008
Reddy heater 170T ignitor (#PP200) not glowing at start up.
if its the ceramic glow rod they brake easy and cost 40.00 plus some times usually broke down next to the base ceramic only ever had one power supply go on me but hard to dignose
Dec 09, 2013 | Heating & Cooling
Sometimes the heater throws out raw fuel out of the burner and sometimes if I cut it off and wait a little bit it will ignite and come on and then it will work normal with the thermostat. Is there...
turn the adjustment srcew clockwise a little to raize the pressure.. check your gap on the spark plug /igniter .060. also check the air pressure should be 6.5#
Jan 23, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Can you burn diesel fuel
Hi, If this heater is the Reddy 170,000 b.t.u. heater, model # 170t professional series, then yes you can.It is a multi-fuel heater. Fuels it can use are Kerosene, JP8, Jet A fuel, 1&2 Diesel fuel, and 1&2 fuel oil. It must be this model 170T.
Sincerely,
Shastalaker7
Jan 19, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Need thermostat for 170t reddy heater
reddyparts.com still has most parts for reddy heaters even though reddy heater went out of business in 98.
Feb 09, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't light
My suggestion would be to clean the nozzle and the fuel lines. Make sure after they are clean you have a good mist from the nozzle.
Mar 18, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dead Reddy heater 170T
When chaning the filters, did you clean out the flame chamber, a lot of carbon and suot will build up inside and cause the unit not lite.
Feb 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
533 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
