Question about Bosch Washing Machines
Bosch classixx 6 1200 express 1200 and 600 light flashing
Doesnt finish wash cycle spin lights flashing
barkencoa
  • 3463 Answers
SOURCE: Bosch Classixx 1200 Express wont spin!!!! HELP
Make sure that all the water has drained from the washer, if it has a filter, remove and clean, it is located behind a removable plastic panel at the front of the m/c, if it still does not spin, suggest you remove motor and check the brushes for wear, this is often the reason it won't spin, but will wash o/k.
Plz rate my solution.
Thanks
Posted on Dec 22, 2008
barkencoa
  • 3463 Answers
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Posted on Dec 09, 2009
SOURCE: Bosch classixx 6 1200 express has F17 on display
fault F17 error code appearing. What does this mean ? thanks
Posted on Jan 24, 2010
  • 662 Answers
SOURCE: Got the Bosch Classixx 6 Express 1400 washing machine cant
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
Posted on Jun 17, 2010
Macmarkus
  • 2605 Answers
SOURCE: bosch classixx 6 1200 express is
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
Posted on Aug 19, 2010
All the lights on the spin speed panel light up and flash when switched on, no other sign of it starting a cycle, any clues please.
motor fault , change the carbon brushes and reset pcb. goggle e21 error its the same process to reset ..
Jan 29, 2015 | Bosch Washing Machines
Bosch classixx 1200 express
check you filter and if not blocked check your pump
Feb 10, 2014 | Washing Machines
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Thanks
Dec 22, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
May 28, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx6 1200 express
my classixx6 1200 express is flashing f21? what is wrong with it?
May 16, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
129 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
