Question about Canon FAXPHONE L170 Plain Paper Laser
Paper has dark marks down middle
Why does my incoing fax pages have dark areas down middle of page
  • marmarr2 Oct 24, 2008
    Thank you. Problem solved!!
  • 2,039 Answers
If you make a copy, does the copy have dark areas down the middle of the page? If so, remove the toner cartridge and gently roll it around to redistribute the toner inside, maybe even replace the toner cartridge if you've had it a long while. If you still see unevenness, you may need to have the machine looked at.
If the copies you make on your machine look fine, then I would suspect that the person sending you the fax has a dirty scanning element. Check with them to see if they can clean the scanning element and it should improve the fax quality.
Posted on Oct 24, 2008
Receiving faxes with dark grey streks going down the middle of the page. Would this be a needing a drum issue
hi ;
  1. remove the cartridge and shake it ten times
  2. Clean the interior with a vacuum cleaner
  3. it can be a problem of cartridge try to use anotherr Dictionnaire - Afficher le dictionnaire
    1. verbe
      1. clean
      2. clear
      3. wash
      4. wipe
      5. clean out
      6. mop
      7. scavenge
      8. mop up
      9. swab
      10. clear away
      11. scour
      12. rub
      13. weed
      14. polish off
Aug 17, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Samsung fax copying - line on middle of page
check if there is any kind of leank inside the printer. do a manual servicing once.
Jul 28, 2009 | Samsung SASSF560 - SF-560 Plain Paper...
Black line down middle of page
Clean off the glass place where the paper passes when you fax. You'll probably find some foreign matter on it. Wipe it off and you should be good to go.
May 01, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Black line going down the middle of the page
lift the auto feeder and clean the scanner glass that your pages scan across -it is dirty. You can make a copy afterward and this will tell you if you have solved the problem.
Mar 05, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Canon pc981
either dubree on the rollers or on the corona wires, wires clean with acalohol and q-tip, very carefully or you will brake the fire, look where the line is at and open the machine and locate where the issue is and remove and clean this area very carefully.
rod
ps
type in address bar
canon pc981 l170 a mark down the middle of paper
enter
rod
Feb 06, 2009 | Canon FAXPHONE L170 Plain Paper Laser
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Gray line down middle of faxes/copies on panafax uf880
yes change a toner and clean the glass area under nearth the toner.
Oct 24, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
HORIZONTAL Lines on faxed/scanned pages.
I've seen this before. Since the printer portion is working fine that points to the scanner mechanism as the culprit. There are two things I have seen cause this. 1) If the line is a perfect rectangle all the way to the edge of the page then the light bar itself is dying and there isn't much you can do to save the unit. Send it in for warranty repair if you have the option. 2) If the line is more like a skid mark like you mentioned, then the paper that is being scanned is not pressing up fully against the light bar. Not enough light is bouncing off the page and the scanner can't read it well. This can also be caused by a roller not feeding correctly and then bunching up the paper a little bit. I would check the rollers for wear or something being off center. This can sometimes be caused if the machine has ran a high volume or thick paper. I would really think the cause would be one of these two since you are getting the marks at odd intervals, if the intervals were regular it could *possibly* be the drum but as I stated before, with the print function working right, I doubt it.
Aug 22, 2007 | Brother IntelliFAX 4100 Laser Fax
Canon FAXPHONE L170 Plain Paper Laser Logo
187 people viewed this question
old marine
old marine
