Question about Canonical Ltd. Ubuntu
HOW TO INSTALL UBUNTA - Canonical Ltd. Ubuntu
    President:
  • 281 Answers
How to remove thermostat on 06 Toyota alvlon 3.5 engine
(a) Install a new gasket to the thermostat. (b) Install the thermostat with the jiggle valve facing up.
HINT:
The jiggle valve may be set within 10°of either side of the prescribed position.
2. INSTALL WATER INLET
Torque: 10 N·m (102 kgf·cm, 7ft·lbf)
3. INSTALL RADIATOR HOSE OUTLET
4. INSTALL IDLER PULLEY SUB-ASSEMBLY NO.2
5. INSTALL FAN & GENERATOR V BELT
6. INSTALL ENGINE MOUNTING BRACKET FRONT NO.1 LH
7. INSTALL ENGINE MOUNTING CONTROL BRACKET
8. INSTALL ENGINE MOVING CONTROL ROD
9. INSTALL V-BANK COVER SUB-ASSEMBLY
10. ADD ENGINE COOLANT
11. CHECK FOR ENGINE COOLANT LEAKS
Jan 29, 2016 | Toyota Cars & Trucks
Dell studio one touch screen is not working
DO NOT install Dell Touchscreen driver as it does not work with MS Touch Pack
Update Windows
Install Dell Fingertapps Touch Zone.
Install Dell Cozi YouPaint, Dell TouchCam, TouchCam Update
Install MS Touch Pack. Find here - http://forum.tabletpcreview.com/showthread.php?p=179262
Install MS XNA 3.0
Install MS Bing Virtual Maps 3D
Install Next Window Touch Screen Driver 1.3.2.5. Find here -http://www.nextwindow.com/nextwindow_support/download_confirm.html
Optional - Uninstall MS XNA 3.0, Install MS XNA 3.1
Sep 02, 2013 | Dell Computers & Internet
Need timing belt digram for a 2000 kia sportage
  1. Install lower timing belt cover.
  2. Install upper timing belt cover.
  3. Install power steering drive belt and adjust belt tension.
  4. Install fan pulley.
  5. Install generator drive belt and adjust belt tension.
  6. Install A/C drive belt and adjust belt tension.
  7. Install splash guard.
  8. Install fan and fan shroud.
  9. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  10. Install fan shroud mounting bolts.
  11. Install fresh air duct.
  12. Connect hose to resonance chamber.
  13. Connect battery negative cable.
Apr 17, 2013 | 2000 Daewoo Nubira
HOW TO DOWNLOAD AND INSTALL UBUNTA
you need to go to the Ubuntu web sit and down load the iso image to your computer ether the 64 bit or the 32 bit it demands what your computer is running then burn that to disk then restart your computer and make shore it boots up to your CD drive first and just follow the on screen instruction make shore you down load the desktop version not the [server]
Feb 10, 2012 | Canonical Ltd. Ubuntu
How do u set timing on it? 1.8 engine
Installation
Install crankshaft sprocket on crankshaft.
Make sure mating marks on crankshaft sprocket face front of engine.
Position crankshaft so that No. 1 piston is at TDC and crankshaft key is at 12 o'clock.
Install slack side timing chain guide and timing chain tension guide.
Install timing chain on crankshaft sprocket.
Set timing chain by aligning its mating mark with that on the crankshaft sprocket.
Make sure sprocket's mating mark faces engine front.
Install camshaft sprockets.
Set timing chain by aligning mating marks with those of camshaft sprockets.
Install camshaft sprocket bolts to correct torque.
Apply new engine oil to bolt threads and seat surface.
Install chain tensioner.
Before installing chain tensioner, insert a suitable pin into pin hole of chain tensioner.
After installing chain tensioner, remove the pin.
Install timing chain guide.
Install O-rings to cylinder block.
Before installing front cover, remove all traces of RTV silicone sealant from mating surface using a scraper.
Also remove traces of RTV silicone sealant from mating surface of cylinder block.
Apply a continuous bead of Genuine RTV Silicone Sealant or equivalent to mating surface of front cover. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Check alignment of mating marks on chain and crankshaft sprocket.
Align oil drive spacer with oil pump.
Place timing chain to the side of chain guide. This prevents the chain from making contact with water seal area of front cover.
Install front cover.
Make sure two O-rings are present.
Be careful not to damage oil seal when installing front cover.
Install cylinder head bolts at engine front side as shown in Fig. 55.
Tightening procedure:
Tighten bolts (1 - 4): 6.3-8.3 N.m (0.64-0.85 kg.m, 55.8-73.5 in.lb).
Install oil pump drive spacer.
Install water pump and water pump pulley. Refer to REMOVAL AND INSTALLATION .
Install idler pulley and bracket.
Install RH engine mounting bracket
Install RH engine mounting.
Install oil pan. Refer to INSTALLATION.
Install crankshaft pulley.
Remove ring gear stopper.
Install starter motor.
Install cylinder head front cover.
Apply RTV silicone sealant to cylinder head front cover.
Use Genuine RTV Silicone Sealant or equivalent. Refer to RECOMMENDED CHEMICAL PRODUCTS AND SEALANTS .
Install Camshaft Position Sensor (PHASE).
Before installing rocker cover, apply a bead of Genuine RTV Silicone Sealant or equivalent, to mating surface of cylinder head as shown in .
Install rocker cover gasket into rocker cover.
Install rocker cover and tighten in numerical order as shown in
Install spark plugs.
Install ignition coils.
Install front exhaust tube.
Install front/right-side splash undercover.
Install front RH wheel.
Install drive belts.
Adjusting drive belt deflection..
Nov 29, 2010 | 2002 Nissan Sentra
My lap top is opening the desk top, Its asking for Vista Product key, what should I do?
You must type in the Vista Product Key from your Vista Disc or purchase a licence direct from Microsoft or use a different operating system like Linux or Ubunta, the latter is free ware and is open source.
Oct 30, 2010 | Computers & Internet
Remove ignition switch for a 2004 kia optima
Ignition Switch Removal & Installation To Remove:
  1. Disconnect battery negative cable.
  2. Disarm air bag system.
  3. Remove driver air bag module.
  4. Loosen screw and lift horn pad to remove.
  5. Remove lock nut and washer. CAUTION
    Do not hammer on steering wheel. Damage can occur to the energy absorbing portion of the steering column.
  6. Pull dynamic damper forward and lift up to remove.
  7. Remove steering wheel.
  8. Remove steering column shrouds.
  9. Remove lower cover.
  10. Remove multifunction switch.
  11. Remove entire lower portion of dash.
  12. Remove mounting fasteners and lower steering column.
  13. Remove bolts and separate ignition switch from steering column.
To Install:
  1. Install ignition switch to steering column and install bolts.
  2. Raise steering column and install mounting fasteners.
  3. Install lower portion of dash.
  4. Install multifunction switch.
  5. Install lower cover.
  6. Install steering column shrouds.
  7. Install steering wheel.
  8. Install dynamic damper.
  9. Install washer and lock nut.
  10. Lift horn pad and install screw.
  11. Install driver air bag module.
  12. Connect battery negative cable.
Jul 17, 2010 | 2004 Kia Optima
WHEN I INSTALL LINUX FEDORA, I WAS UNABLE TO PLAY THE VIDEOES AND MP3 SONGS N NEITHER ANY EXE FILE EXECUTED.....
In order to play MP3's you will need to compile and install the " lame " audio codec's.
You will also need to install codec's to play back video.
You will also need to install Wine to run windows EXE's within linux.
To install A large package containing the most popular codecs
I believe you need to install the livna repository if you have notalready done so. The instructions for doing so are located here : Livna
Then you can install with yum
amarok-extras-non-free
you may also need to install
gstreamer
gstreamer-plugins-bad
gstreamter-plugins-ugly
and perhaps some others .. just do a yum list | grep gstreamer
or
yum -y install yumex
and you can use yumex [gui for yum] to search
You may also want to install the codec package which you can grab here : Codecs
And follow the instructions here to install them : Installation
To install Wine you can simple type the following command into any shell / terminal available
yum install wine
or
su yum install wine
May 31, 2009 | ASUS Computers & Internet
All downloaded music is "unknown" artist, title etc.
Hey, I am not sure about ubunta but in Windows, you need a program that "tags" the MP3. Just google MP3 tag editor and you will find some programs that do this. Again, not sure about ubunta but give it a shot. What this program does is let you edit the MP3 to the fullest. Song title, artist, album, everything...Check it out....
May 30, 2009 | Philips GOGEAR SA6045 MP3 Player
Canonical Ltd. Ubuntu Logo
75 people viewed this question
Top Canonical Ltd. Computers & Internet Experts
k24674
Jaipal Reddy
Jaipal Reddy
Are you a Canonical Ltd. Computer and Internet Expert? Answer questions, earn points and help others
