Question about Telex Computers & Internet
I have some Telex FMR-25TD mikes. I am having a short problem. Do you have any info to help me?
I want to use these but when I turn unit on all lights go on & i get static. When I turn on the transmitter mike it quits. What do you think might be the problem?
3 Suggested Answers
  • 355 Answers
SOURCE: Hi.The writer unit is not copying.
cleane the lence from lence clener then try it
Posted on Oct 02, 2009
electrotech1
  • 1126 Answers
SOURCE: I have a telex FMR100
You should be able to take it to a shop where they have electronic techs, even a TV shop and they should have it repair under a hour.
Posted on Mar 17, 2011
Telex Copyette 1-2-3: Master well wraps tape around the capstan.
Tape wrapping on a capstan shaft is commonly due to a sticky pinch roller or capstan shaft but is also because the take-up reel table does not provide enough torque or tension to gather up the tape. The Teac MTT160 cassette is a test tool we use to determine what the deck is doing torque wise. Telex probably has something similar. I worked with a guy who worked at Telex in the tape business- He did not talk about them much but he did say they had a lot of belts in them. Maybe you are just dealing with a belt that needs to be replaced. Lubrication also tends to be needed at every rotation point as well. That would include reel tables. I hope this gives you some help as Telex repairmen are getting to be like Hens teeth.
Aug 24, 2012 | Telex Copyette 1-2-3 Single Dual Cassette...
ProStar UB12. When I turn on the wireless, I get occasional static that is irritating to the point I cannot use it. Is there a fix?
I had the same problem. Mostly, when using near energy saving fluorescent lighting. I would receive high static, especially when the mic was off. We were using it indoors & usually no more than 200 ft from the receiver. I opened it up, resoldered some poor solder connections, sprayed contact cleaner on the squelch & volume controls, but still had the problem. What actually resolved the issue, was turning the squelch control (thru back panel) fully clockwise & completly lowering the antennas aimed horizontally to the rear. If you are using it outdoors, you should not have interference from fluorescent lighting, but may need to raise the antennas if operating from a greater distance.
Sep 16, 2010 | Telex FMR-200H Professional Microphone
Wireless lapel mic uses batteries at the rate of one per day. Even if the unit is off, the battery still goes dead..
As long as the battery is in the microphone, the microphone is on and transmitting. Even if your receiver is off. Remove the microphone battery when not in use. Life expectancy of an Alkaline battery is about 4 to 8 hours stage time. Only 1 to 2 hours for heavy duty batteries.
Feb 23, 2010 | Telex FMR-500 Microphone
What are the specs of a power adapter for an old Telex FMR-2 wireless reciever.
Check this out-including specs receiver. hope this will help ........................................
http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch%20-%20EV/FMR-450.pdf
Aug 08, 2009 | Telex FMR-500 Microphone
Electro voice ma-1212 shorted 2sd5200 power transistors
Your best bet would be to contact EV. Search for either EV or Telex. Telex will be easier to find and contact the repair department. Ask for the part availability and cost. They are very helpful there. Please let them know the model number as well.
Dan
Apr 16, 2009 | ElectroVoice...
Telex WT55 wireless lapel mic & FRM70 Receiver
How do I set the squelch on a TELEX FMR-70 receiver?
Jan 27, 2009 | Telex FMR70 VHF Wireless Microphone...
Telex ProStar VR12 VHF needs repair
I've been in contact with Telex and although the Prostar is obsolete they still maintain some repair parts. I would contact them:
http://www.telex.com/Support/
Jan 07, 2009 | Telex FMR-200H Professional Microphone
Telex prostar wireless mic.  leads came off of mic element.  One green wire and one black.  Which one connects to center of element and which connects to rim.
Hi..
The rim is "ground" or the (-) side of the mic.
Find out which wire goes to ground or a (-) on a battery.
Solder that one back to the rim
Dec 11, 2008 | Telex FMR-200H Professional Microphone
Computers & Internet Logo
41 people viewed this question
Top Telex Computers & Internet Experts
Longtime User
ray gallant
Tom Chichester
Are you a Telex Computer and Internet Expert? Answer questions, earn points and help others
