Question about Toshiba DR410 DVD Recorder
How to connect a Toshiba DVD video recorder to a tv
Need to know how to hook the Toshiba DVD video recorder DR430KU to a TV (ro record programs)
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: DVD VHS Recorder setup.
hi there, a little late.....but here we go........do you have cable? if yes connect the cable from the cable box out to dvd in and connect the dvd out to tv in.......pls note the dvd and tv must be set/tune to ch #3.(and you cannot record HBO)......you dont have cable just tv and dvd you need rca wire (red,white & yellow) also the F connector wire....in back of dvd connect the 3 wires audio in video in (is your tv/monitor a flat panal these connections might be on the side) if not its in the back plug in to out on tv....(this is so you can record)....plug the F conncetor wire from dvd to tv......on this connection you can set the dvd to ch #3 or any ch you want to record...........
Posted on Jun 25, 2009
dvdcdlaser
  • 1285 Answers
SOURCE: how to finalize a recorded dvd disc?
on the remote is there quick navi button (this will take u to the finalizing screen)
Posted on Jun 26, 2010
  • 11800 Answers
SOURCE: Unlock Toshiba DVD Video Recorder
In this recorder the region is hard coded in the firmware and cannot be changed thru customer commands. Unfortunately there is no region free firmware so if you would be able to obtain one all you would manage is to change the present region to another one.
Posted on Dec 08, 2010
Trying to record with my DR430KU Video Recorder from my Sharp T.V.Set
The input to the recorder needs to be set correctly. Describe in detail your connections between the TV and recorder and I can tell you what you are doing wrong.
Nov 19, 2012 | Toshiba Dr430 Dvd Player/recorder
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Feb 11, 2012 | Zenith Televison & Video
Have a toshiba tp 61H95 proj TV- want to connect panasonic dvd recorder and toshiba vhs recorder so I can copy family videos to dvd- can't get hook ups set up for both to work.
Select AV-1 or some thing in TV and plug DVD recorder Video-Audio output in AV-1 input of TV, playback any DVD and confirm its picture and sound in TV. Press Stop button of DVD recorder to stop playback.
Now plug Video-Audio output of VCR in DVD recorder input and select AV Input in DVD recorder, insert VHS tape in VCR and playback it and confirm you get VHS picture and sound in TV via DVD recorder.
Hookup between TV, DVD recorder and VCR is completed.
Playback VHS tape in VCR, Insert blank DVD disc in DVD recorder and press Record while you see VHS tape picture in TV.
Hope this info will help you.
Feb 03, 2010 | Toshiba TP61H95 61" Rear Projection...
How do i hook up dvd recorder/vcr to my tv?
Hello.
VCR -
DVD
/Tech5508
Feb 13, 2009 | Toshiba DVR610 DVD Recorder/VCR
Jul 19, 2008 | Toshiba D-VR4 DVD Recorder/VCR
Hooking up a DVD player to a LCD TV
Typically, there is no video out from TV. You would have to connect the satellite receiver output to the DVD recorder input and connect the DVD recorder output to the TV. Word of warning - digital signals (DTV coax or HDMI) from the satellite receiver carry copyright info embedded, which may limit what it will allow you to put on a DVD. Typically anything can be recorded on the hard drive of the recorder, but programs from subscription channels may not go to a DVD.
Jul 08, 2017 | LG 42LB5D 42 in. LCD Television
Toshiba DR410 DVD Recorder Logo
347 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
