Question about Philips GoGear HDD084 MP3 Player
Delayed write failed
When my Gogear kept needing to be reset I ran the System Restore program and it popped up a Format E: window. At the end it stated that "windows could not complete the format" and now when I connect it to the PC it recognises that it's there but if I try to synch, browse or even "upgrade firmware/restore" it then says that the device is not connected and I have to go through the reset or disconnect and reconnect before it recognises it again but still won't allow access.
  • 8,596 Answers
Uninstall and reinstall the software
Posted on Feb 19, 2008
Resetting nextbook 10.1 windows
There is no reset like a tablet, you must do a system restore and if that doesn't work you must reload the operating system. System restore is located in system tools menu in pop up start menu under all programs..
Feb 15, 2017 | Nextbook Tablets & eReaders
It comes on says file system error and shuts off what can i do reset isnt working
May need to update firmware which can be done using Songbird.
In Songbird if your unit is showing click on you units name.
In the main window click on Tools
there will be a list of options. First try to update the firmware. current version as to date (10-15-2014) is 2.12
If you already have it skip.
DO NOT DO FORMAT unless you want to lose absolutely everything music videos programming of unit. Instead do the restore.device.
Also on the bottom of the unit is a reset button. This also will erase anything you added but not the programming.
Jul 22, 2014 | Philips Gogear Vibe 8gb Mp3 Player...
How do i reset advent milano to factory settings?
Hi there!
There are two ways to start the recovery:
Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed. Just follow the instructions on the screen to restore your computer
In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
The recovery will load and display a box with one option:
Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
To access the recovery options below that erase all data from the computer, click the Advanced button.
System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
Select the Non-destructive recovery option and press Next. You will be informed about System Restore in Windows, click Yes.
The recovery will begin. Once this is complete click Restart.
Hope this helps.
May 10, 2011 | Advent Netbook
My computer says configure updates and then it automatically turns off
This will be a long process of troubleshooting and may end up of restoring your computer to a factory settings. You can try the steps below:
First is boot up to advance boot options, to do this follow the steps below: -Turn off your computer -After pressing the turn on button start tapping F8 key until you see the Advance Boot Option. -Try choosing Last Known Good Configuration if it fail try Safemode, Safemode with networking or safemode with command prompt, if one is successful use system restore to restore your computer to an earlier date but if it fails you'll need to use your Operating System Disc to use the repair option.
Here's how to access system restore incase you're able to access Last Known Good Configuration, Safemode, Safemode with networking or safemode with command prompt: Windows XP: Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
Windows 7 and Windows Vista: Click Start, point to Programs, point to Accessories, point to System Tools, and then click System Restore select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If you're on safemode with command prompt: At the command prompt, type %systemroot%\system32\restore\rstrui.exe, and then press ENTER, System Restore window will pop-up then select Restore my computer to an earlier time then select a bold date on the calendar and click Next on the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows configuration, and then restarts the computer. Then click OK on the System Restore Restoration Complete page.
If all the steps above fails you need to use the recover disc or the operating system disc to do a repair on your computer. Revert back in case you need steps for using start-up repair.
Note: If the steps above and start-up repair fail there's no other option but to restore your computer to factory settings.
Apr 21, 2011 | Acer Aspire AX1700-U3793A PC Desktop
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
I cannot boot up laptop it says control alt delete then nothing
You need to try booting in Safe Mode with Networking and if that fails then Last known good configuration should work. Below are the steps to perform Last known good configuration howver Safe mode with networking is also an option under "windows Advanced option". Now if you succeed logging in to Safe mode with networking then try performing system restore by going to Start....All Programs....System Tools and System restore.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
All the Best
Dec 27, 2010 | Samsung Computers & Internet
My mp3 freeze i cant do any thing
On the left side of the player below the hold button is a hole labeled rmoz-screenshot.pngeset. insert an unbent paper clip until the unit shuts down (Blank Screen). Then press the play/pause key until unit lights up.
If this fails, the firmware of your GoGear may be corrupted.
  1. Make sure that your computer is online and connecting to the Internet. Launch the Firmware Manager at Start->Programs->Philips Firmware Manager on your PC
  2. Connect your GoGear to the computer while pressing & holding the 051104154033_4112.gif key until the Firmware Manager recognize the GoGear and a dialogue box pop up in recover mode.
  3. Click Start to confirm and start recovering the unit to its factory setting
    IMPORTANT: All music & content of your GoGear Player will be erased once the factory setting is restored.
  4. Follow all screen instructions and click Finish at the end to complete the recovery.
  5. The Firmware manager will close automatically once the success message is displayed. Close all opened application and then safely remove your GoGear by clicking on the EJECT HARDWARE icon in your task tray bar. When prompted, "The USB Mass Storage Device can now be safely removed from the system", click OK and unplug your micro jukebox.
Dec 24, 2010 | Philips GoGear SA178 MP3 Player
How to do an advent 7113 laptop factory reset, tried pressing f10 at start up but not sure what to do after that
hope this helps
  • There are two ways to start the recovery -
    • Restart your computer. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
    • In Windows by clicking: Start / All Programs / System Recovery / System Recovery.
  • The recovery will load and display a box with one option:
    • Non-destructive recovery: this option will restore Windows, supplied applications, and drivers. This option will not destroy your documents or programs. These will be backed up along with the registry. These are restored at the end of the recovery process.
    • System Recovery - No format: this will reinstall Windows, supplied applications and drivers. It will move your files to a folder called "My old disk structure". Any applications (except those supplied) will need to be reinstalled.
    • System Recovery - Quick format: this option will erase your hard drive including your personal files. Windows, supplied applications and drivers will be reinstalled.
  • Select the Non-destructive recovery option and press Next.
  • You will be informed about System Restore in Windows, click Yes.
  • The recovery will begin. Once this is complete click Restart.
Nov 24, 2009 | Computers & Internet
How to master reset my advent laptop
Hi
Restart your laptop. Then Press F10 repeatedly until the message "Starting System Recovery" is displayed.
In Windows by clicking: Start > All Programs > System Recovery > System Recovery.
To access the recovery options, that erases all data from the computer, click the Advanced button.
Sep 12, 2009 | Computers & Internet
FROZEN On NON SUPPORTED FORMAT DETECTED SCREEN
Reset the player by inserting a paerlcip into the reset hole. If that fails, go to Philips' website and upgrade the firmware on your player to solve the freezing issue permanently. Actually, don't go to Philips website - run the Philips Device Manager and select Update. If the device manager won't recognize the player, unplug the GoGear, hold in either the shuffle button or volume + and reconnect it to the computer until a Found New Hardware Wizard window pops up. Once all this is done, use the Philips Media converter to convert all your video files from now on.
-Tha Mp3 Doctor
Dec 08, 2008 | Philips GoGear SA5285/37 Digital Media...
Philips GoGear HDD084 MP3 Player Logo
61 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
