Question about JVC AV-27720 27" TV
JVC AV-27720 TV Problem: Picture goes to horizonal white line in center.
First, a little background. This TV worked fine until cats used the TV top case as a launching point. The screen would compress, then it finally went to just a horizontal white line in the center. Note that before it went completely bad, I could press on the top case and cause the picture to go back to full size.
Upon disassembly, I noticed that the only thing the top case was pressing on was a grey cable that is routed around the picture tube and is terminated into a 2 pin connector on the main PCB. The cable does have creases where the case was pressing. If I disconnect the cable, nothing changes.
I'm an old electronics tech (i.e. rusty), and I don't have schematics. I can perform basic AC/DC voltage tests, but don't have a signal tester/Oscope.
I'd hate to throw this TV out! Can you provide any insights or instructions on how to troubleshoot?
Joe (joejjt)
  • 89 Answers
In most cases the following parts need to be replaced I think the part location numbers are accurate
IC421 LA7832 ( vertical output IC )
Capacitor C424 100UF @35v
Zener Diode D422 MTZJ75-T2
Resistor R541 1.8ohm 2watts
Posted on Mar 12, 2009
JVC flatscreen tv model Number AV-21mt35 with vertical interference? how to solve this problem?
It will be best to replace its Line Output Transformer [LOT]. It is not good to join the broken EHT wire. EHT arcing cannot be stopped by using glue.
Apr 04, 2013 | JVC AV-27720 27" TV
Describe your jvc av-27720 Problem no power main fuse ok.
Look in middle of board for C926 or location like that--it should be 1000 mfd at 35 volts--fails a lot in these sets.
Let me know if you have questions as I am here to help.
Aug 25, 2010 | JVC AV-27720 27" TV
Picture on my JVC AV 32120 is a little jumpy and has fine horizonal black lines going thru the picture. This happens if I use the cable connection or the RCA plugs connection. If I pound on the top of the...
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks!
Oct 19, 2009 | JVC AV-32120 32" TV
Sound is fine, picture not
You have a vertical deflecttion chip that is going bad. Probably a LA7832. There is also a good chance that you have a leaky capacitor and bad zener diode. The capacitor is east to get , the zener diode part # is MTZJ75. These repairs are usually best left to a professional
Feb 22, 2009 | JVC AV-27720 27" TV
The only thing that happens is the red power light is flashing
The Vertical output ic is bad la7832 also has an open resistor in power supply off of pin 7 the ic.
Root cause is probably the zener diode next to the IC itself MTZJ75
Dec 23, 2008 | JVC AV-27720 27" TV
JVC AV-27720 27" TV manual
GO to www.Service you should be able to find it there!ThankYou for using FixYA.Have a Nice Day.
Feb 17, 2008 | Televison & Video
White lines at top of av27230
Your posted description is a known (common) problem for the JAV-27230 and should be easily repaired. The vertical capacitor (C424 - 100uf/35V) needs to be replaced. It is relatively cheap and can be bought from any electronics parts store.
in some instances, it could be the vertical IC starting to fail or even a simple case of cold solder.
As always, extreme care when repairing the insides of a TV unit since HV can still be present even when off and unplug. A little knowledge of electronic components and use of a soldering iron should do just fine. Should you not be comfortable doing a DIY, then perhaps you can ask the assistance of a buddy who has some soldering experience.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
good luck and kind regards.
Feb 10, 2008 | JVC AV-27230 27" TV
try using AV im puts with dvd or vcr if this work your tuner is bad new cost aruond $90 to 120 if available but next year you wont have use for it
Sep 25, 2007 | JVC AV-48WP74 48" Rear Projection...
Jvc AV-27720
In my case the solution for this problem was the transistor replacement. The jonction E-C and B-E was bad. Rplacer by the ECG 2331 part on NTE.
Oct 30, 2006 | JVC AV-27720 27" TV
Televison & Video Logo
185 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
