Question about Toastmaster Coffee Makers & Espresso Machines
Toastmaster 530 manual
Broken carafe and grinder blade
3 Suggested Answers
SOURCE: Need replacement carafe for Toastmaster TCM 12 Coffee maker
Found one at Target.
Posted on May 20, 2008
safenude
  • 124 Answers
SOURCE: toastmaster coffee carafe, model TCM4W
Welcome to FixYa! I hope my solution will help you get the information you need. If so, I would appreciate a FixYa rating, which is our highest form of recognition for good work. The coffeemaker is a Salton brand. You will be able to order the part you require.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Thanks again for allowing me to help you and thanks for using FixYa!
Posted on Jan 31, 2009
Can I order 2 blades for my 1119 Toastmaster electric coffee grinder?
The grinder is available for under $20 (Amazon.com sells it for under $15). At that price it's a throwaway item and no parts are available.
Jul 20, 2011 | Toastmaster 1119 Electric Blades Grinder
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
I just broke the glass carafe for my Toastmaster Espresso Coffee Maker, Model TEM4022C. Do you know where I can purchase a replacement carafe? Also, I need an instruction pamphlet for the same coffee...
Carafes are available at hardware stores and cook's supply stores. To get you by till then (providing your coffee maker doesn't have a 'sneak-a-brew' stopper at the bottom of the filter cone) you can use a small saucepan and reduce the recipe, (water and coffee).
Mar 29, 2011 | Toastmaster TCM10 Coffee Maker
The tip on one side of the grinder blade has broken off...the machine runs well and has not had a lot of use. Can the blade be replaced; if so, how, and how much? SmartGrind CBG5.
I have two different coffee grinders and if it is just the tip of one side of the blades you can continue using it, if there is a large portion that is broken I'm not sure of that model. Hint: check to see if the part is still in the grinder set the grinder for the most coarse grind, don't turn it on, shake it upside down to see if the broken potion is still in the grinder. If you find nothing use the grinder unless the performance is less than you like.
Feb 10, 2011 | Black & Decker Black and Decker CBG5...
Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Toastmaster coffee carafe, model TCM4W
Jan 17, 2009 | Toastmaster TCM4W 4-Cup Automatic Drip...
Need operating directions. It came with no manual.
My Toastmaster Breadmaker TBR15 came with the Kneading blade open on the top of it. The salt settles in to the open hole. Where can I get a kneading blade?
Apr 19, 2008 | Toastmaster 1148X FastBake Bread Maker
Water is leaking from bottom of base.
I just had good luck pulling the grinder bottom piece forward while pulling directly up on the blade mechanism. Hope this helps.
Dec 25, 2007 | Cuisinart DGB-600 Coffee Maker
Coffee Makers & Espresso Machines Logo
57 people viewed this question
Top Toastmaster Coffee Makers & Espresso Machines Experts
eyecam
Douglas Dinnebeil
Douglas Dinnebeil
ray gallant
Are you a Toastmaster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
