Question about HP DesignJet 110 Plus InkJet Printer
Hp desinghjet 110plus has new ink,but show empty
Has new ink,but show empty
SOURCE: HP D7160
replace the carrage unit in the printer
Posted on Sep 19, 2008
  • 99 Answers
SOURCE: Our hp designjet 110plus is not printing black
Check whether the black cartridge is dry and whether it is releasing the ink properly.  This you can check by rubbing the paper on the place where the flows.
Else check with a new cartridge.  Even if the problem continues in the printer preferrence you have an option of service.  click on it and the problem will be fixed......!
Posted on Mar 13, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
michael_grey
  • 365 Answers
SOURCE: Ink Cartridge shown empty on HP 7780
How did you do the factory reset?
Take out all cartridges and heads then unplug for 30 minutes?
Plug back in and reseat all removed items?
If so you probably have a bad head.
You can order them through HP or Staples.
The heads have a very short life of 10,000 pages.
Posted on Jul 21, 2009
  • 43 Answers
SOURCE: hp business inkjet 1200, replaced ink cartridge
the error's you were getting on the CIS could have been from the chip. Try setting the date back on the computer or on the printer back 1 year. See if that makes a difference (if you still have the CIS and the printer). Best advice, get an updated chip.
Posted on Nov 22, 2009
Will not print put new ink in it was not used for 2 years
You need to clean the print heads. Use qtips and rubbing alcohol. It will take some soaking and multiple cleanings
Mar 16, 2014 | HP Designjet 110plus nr InkJet Printer
Hp Designjet 500 not recognising ink cartridges. the ink carts were nowhere near empty but coming but the printer says replace bought new ones and put them in and the machine is not recognising them...
I've had that problem with unfinished cartridges showing up as empty. I imagine that it could be a bad cartridge as well but I hear and feel the ink when I shake the cartridge. Therefore the ink is there. I also have a problem with some inks. I find the HP inks work perfectly whereas other manufacturers' inks work on and off. I need a solution as well. Right now I have full cartridges that are not picked up by the Designjet sensor. Any idea?
Jul 15, 2010 | HP DesignJet 500 InkJet Printer
We have HP Designjet 110plus. Our magenta is flashing saying that it is out of ink, however it wasn't. We replaced it with a new cartridge, and it still reads empty. Please help!
Turn off the printer, disconnect and remove everything like power cable, usb cable, cartridges etc.. Connect your power chord and power on, leave it for few minutes (clean the cartridge interfaces not the head, and the corresponding interfaces on the printer). Again shut down the printer using the power button. Reconnect/reinsert everything, and again power on the printer before you connect the Usb to the computer. Now check if it helps or not. This will clear any static memory/voltage. Good luck Thanks for using FixYa.
Jun 01, 2010 | HP Designjet 110plus nr InkJet Printer
Black ink started to print blue/mauve
Many thanks for the suggestions received. Have been told by HP to
change the black printhead - which has solved the problem!
Dec 22, 2009 | HP Designjet 110plus nr InkJet Printer
Trouble with Designjet 110plus: Cannot get Cyan or Black to print. When I change the printhead, the machine does not recognize it for both black and cyan. Machine DOES NOT show error on any printhead or...
Hi Paula, first of all, take out the Continuous Ink System. Second, make sure that the new printhead are good and work propretl, try to get them in another HP 110, if their work good and at your HP not working good whitout your Continuous Ink System replace the carriage assesmbly, but before that verify tge tubes of ink. Good look
Aug 03, 2009 | HP Designjet 110plus nr InkJet Printer
Black ink cartridge show empty in ink system
Clean the Cartidge carrier (metel pcb dots) with ISO profie and fix..Othe wise replace the Cartridge.
Jul 10, 2009 | HP Designjet 110plus nr InkJet Printer
Our hp designjet 110plus is not printing black though the indicator shows we have black ink, what seems to be the problem? -Leh
Mar 13, 2009 | HP Designjet 110plus nr InkJet Printer
HP Business Inkjet 2800 Problem
there is a sensor which recognises the amount of ink u have in ur cart. if that sensor doesnt work, then printer will not recognise the ink in the cart. Try cleaning the copper contacts on the printer cart slot. if no go. look for service..
Sep 25, 2008 | HP Business InkJet 2800 Printer
HP DesignJet 110 Plus InkJet Printer Logo
51 people viewed this question
Seeker5211
Seeker5211
