Question about Sony PlasmaPro FWD-42PV1A/S 42 in. EDTV-Ready Television
El problema es , cuando oprimo el encendido solo enciende el led verde y no funciona la tv
Tengo una Tv plasma .SONY Modelo N. FWD-42PV1, 42'
Y el problema que tengo es que cuando oprimo el boton de encendido solo
enciende el led en verde,es todo gracias.
3 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: No enciende tv. La luz
When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components, check your system input settings, verify your display settings, and confirm that your properly connected to your cable service.
Posted on Jan 16, 2011
  • 963 Answers
SOURCE: Hola. Cordial saludo. Tengo el siguiente problema
Mi espa?ol es s?lo un poco. Utilice traductor Google (translate.google.com) para obtener esta informaci?n:
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
Resalte con el rat?n y pegar en el traductor Google, si es necesario.
Dos parpadeos parece ser un problema de alimentaci?n.
Posted on Mar 05, 2011
Tengo una pantalla de 37 de tft samsung a la que conecto la ps3 por hdmi hasta hora sim problemas hoy la he conectado y me sale modo no compatible que es lo que puede pasar,e probado la ps3 en otra...
Puede ser que se haya desconfigurado el ps3, en caso de que sea este el problema, no desesperes que la soluci?n es muy f?cil. Conecta tu ps3 a tu tv a trav?s del cable hdmi, ahora, cuando enciendas la consola, deja oprimido el bot?n de encendido por unos 5 segundos, esto resetear? la configuraci?n de video de la consola y esta se ajustar? autom?ticamente a tu tv, presiona (X) cuando la interface te lo indique. Si esto no lo soluciona, y la consola funciona en otros tvs, es otra la situaci?n y es probable que tu tv este fallando.
May 05, 2011 | Sony Playstation 3 (PS3) Console
Mi televisor no enciende solo se prende el foco rojo y parpadea en donde dice timer
bueno tengo una television pt4298hd akai el problema no enciende parpadea el foco de timer 10 o 9 veces y no enciende destape la tapa de atras y desconecte un cable rojo que tiene el nombre de screm y la television enciende pero no se mira como debiera porque se mira el color verde y el rojo pero como si le faltara el color azul mi televisor es una dlp akai de tres lentes y quisiera saber cual es el problema
May 02, 2011 | Akai PT4298HD Rear Projection Television
Hola. Cordial saludo. Tengo el siguiente problema con este modelo KDL-46V3000 el cual Al darle el pulso de encendido el led del stanby enciende verde y cambia en segundos a rojo y empieza a parpadear...
Mar 05, 2011 | Sony BRAVIA KDL-40V3000 Television
Hola amigos tengo un problema con un Tv Sony wega modelo kv-29fa515 chassis BA6/9 el tv me enciende osea arranca bien imagen, color y sonido pero alcabo de cinco segundos se me cae la imagen osea queda la...
por favor si alguien tiene informacion que me sirva para arreglar esta falla,le agradesco de corazon.el tv enciende y la pantalla queda oscura,el filamento enciende y los voltages de catodo estan elevados(192v) si aumento el escren, aparece imagen muy al fondo,la pantalla tiene lineas de retorno y cambia de azul a verde.
Jan 12, 2011 | Televison & Video
Tengo un plasma sanyo 50 pulgadas modelo dp50747m lo que tiene es que: no prende y le cambie los fusibles que estban quemados pero ahora se oye que prende pero no se ve nada solamente se enciende el...
Amigo yo tengo el mismo problema con el mismo plasma..y no encuentro solucion...Tu ya pudiste arreglarala?? Ojala pudieras decirme como lo resolviste o cualquier info al respecto...gracias.
Sep 05, 2010 | Sanyo DP50747 50 in. Plasma TV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
LA PANTALLA SE PONE COMPLETAMENTE NEGRA CUANDO ENCIENDO EL AIRE ACONDICIONADO Y SOLO SE ESCUCHA
Dependendiendo donde vivas, y si esto solo ocurre cuando enciendes el aire, es simple que la misma linea que alimenta el aparato de aire acondicioneado, es la misma que esta supliendo energia al TV. El area donde vives debe tener problemas con caidas severas de voltage. Los equipos cuyo consumo de potencia es menor que la inmensa demanda de potencia que requiere un acondicionador de aire, tienden a llevar la peor parte del sunministro electrico. Te recomiendo que busques otro toma corriente para suplir el TV, y para estar seguro de que lo estas colocando en una linea que no esta con el aire, sin encende el aparato de aire acondicionado enciende el TV y ve te a la caseta de breakers, ve bajando (off) uno por uno hasta que veas que el TV se apaga, ponle una matrca a ese breaker ya que es el mismo que suple el aire. Luego conecta el TV a otro tomacorriente y repite el proceso (asegurate tambien de que la nevera esta apagada) si ves que en un breaker diferente al que marcaste hace apagar la tele, entonces dejala en ese toma corriente y con todos los breakers arriba (on) enciende el aire acondicionado) si no sufre la tele, ya resolviste el inconveniente, pero si se vuelve a poner negra, busca un multimetro o tester y asi con el aire funcionando, pon el multimetro en la funcion de voltage AC (voltage alterno) Y mete cada uno de los terminales o puntas del multimetro en un tomacorriente (no hay peligro alguno, el multimetro solo mide) deben haber 120 voltios aproximados con un descenso s ascenso de un 10%, es decir entre 108 a 132 voltios. si baja mucho menos el valor de lo que especifique, entonces tienes un serio problema con la energia que te suministran a tu casa. Si eso ocurre, me escribes y te doy una pequeña solucion a eso...
Dec 29, 2009 | Televison & Video
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Julio cesar vazquez : tellvaz@yahoo.com
in my monitor the two lines r coming can u explain how to solve
May 13, 2008 | TDV Vison F173 17" Flat Panel LCD Monitor
Sony PlasmaPro FWD-42PV1A/S 42 in. EDTV-Ready Television Logo
200 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
