Question about Locks & Locksmithing
Unable to set electronic lock on Alera Cabinet 80362
Purchased ALE80362 Alera Quick-Assemble Electronic Lock Cabinet need help to program setting and passwords for lock, no instructions received with cabinet Keyless electronic coded lock records access and includes power loss backup features;
5 Suggested Answers
  • 8 Answers
SOURCE: How do I change combo of electronic lock
Have you tried removing the cover (inside the house).. there should be a program button, which you press, enter your code, and press again....don't forget to try your code before actually locking the door...
Hope this helps
Posted on Jan 08, 2009
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
  • 963 Answers
SOURCE: How do I set the key pad to my on code on my
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks, including the BE 365:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Posted on Mar 05, 2011
  • 963 Answers
SOURCE: setting keyless electronic lock by
Here is a link to the instructions for the 6101LM:
http://www.larsondoors.com/files/etouch-user-guide.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
If you are not successful after changing the battery and following the instruction sheet, then I suggest contacting Larsondoors.com for Customer assistance.
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Good luck--and please provide feedback if this helps!
Posted on Aug 28, 2011
Hello, I am hoping you can assist. I have a CL1000 lock and I am wanting to change the User Code. Unfortunately, when I use the factory set code it doesn't open. I have tried using the master code...
This web page will take you to a "Help" chart for your lock:
http://www.codelocks.us/need-help.html
If you are in the U.K., use this site:
http://www.codelocks.co.uk/
Try going to the "Code change help" chart and selecting the CL1000.
If you cannot resolve your problem there is a phone number listed on the web page that you can call for technical assistance.(714 979 2900)
Sep 01, 2011 | RTO Codelock CL1000 electronic keyless...
When we lock the door you just have to press the schlage lever on the top of the elecronic keypad and the door opens. Help we don't want to go to bed with the house unlocked
the lock is set in factory mode and needs to be programed to the security code that you choose.
go through the code set up and program in your code and the lock will work as intended.
if there is a problem with the lock and it will not accept the codes then the only way to disable the motor function of the lock is to remove the battery itself and use the key bypass until you can get the lock fixed or replaced.
c...
Jan 21, 2011 | Schlage Lock BE365VCAM716 Electronic...
How do I set the key pad to my on code on my schlage electronic keyless lock
Jan 13, 2011 | Schlage Lock BE365VCAM716 Electronic...
I need to find out how to change my combonation/code. I threw away the papers on it. Thank you.
"How can I program my electronic keypad lock when the instructions with the Programming Code have been lost?"
Complete installation & programming instructions can be found here:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Videos for installing and programming can be found on this page:
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Nov 04, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
I need to programming instructions for this lock. it has a keypad on it and I do not have the instructions for it.
BE-365 installation & programming PDF: http://consumer.schlage.com/Project%20Documents/P515-858.pdf
This number is the programming code referenced in the information for changing the entry code.
Nov 01, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
My schlage lock isn't responding. the battery has been dead for quite some time so I replaced the battery and it is just flashing red now. I tried to reset it to factory settings but it wont do it. It...
Oct 21, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
I know I have set up the code to work and I can hear that is is suppose to be opening or locking but the dead bolt does not move
Oct 19, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
I need to change combination but lost my manual
Oct 02, 2010 | Schlage BE365-CAM BE365CAM505 Lifetime...
How can i reset code on this lock
Sep 27, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Need to reset codes and need instructions, were can I download them to print?
Sep 23, 2010 | Schlage BE365-CAM BE365CAM619 Satin...
Locks & Locksmithing Logo
94 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
