Question about Abit nForce2 NF7-S2 Motherboard
My Abit NF7-S v2.0 only works with one memory module at a time
I have posted the same problem in other forums so I thought I would try here too.  Here it is:
I have an Abit NF7-S v2.0 motherboard with 2x512MB PC3200 Kingston Value Ram which has been working just fine for years. Recently, I booted up my computer and no video was showing. I tried a number of things (explained below), but eventually resorted to a minimal bench build. Even after that, still nothing. So, I tried with only one stick of memory and it booted up with no problems. My first impression was that my other memory stick went bad, but I also tried that one by itself and it worked too.
So, both memory sticks work fine individually, but not together. I know they are compatible because I have been using both for a long time with no problems. I have already Googled my problem and, based off of other people's suggestions, these are the things I have tried.
1) Placing both sticks together in every combination of my 3 RAM slots. (i.e. I have tried slots 1&3, 2&3, 1&2, swapping the sticks each time)
2) Memtest86 on each stick, no errors
3) Resetting BIOS settings automatically (i.e. in the BIOS menu)
4) Resetting the BIOS settings manually (i.e. by clearing the CMOS via mobo jumpers)
5) Lowering the voltage to my memory
6) Raising the CL
All of these things still result in the same problem and I have run out of ideas. Does anyone know why my memory would, all of a sudden, only work one stick at a time, and not together?
Thanks in advance.
I have read that there are dual memory controllers (duel channel) and that when you use 2GB like that you are using 1 memory controller for each stick. Maybe one of your memory controllers is bad... maybe popped a cap? Sounds like time for a new MB. See this thread...
http://www.motherboardpoint.com/t61060-nf7s2-can-it-use-highdensity-memory-chips.html
Posted on Nov 21, 2008
Abit NF7-s
Take out the ram and reseat it. Try again, if you still have the problem, take out half the ram and test it and then switch it around till you find out what ram chips are possibly bad.
Jan 30, 2014 | Abit NF7-S Motherboard
ABIT nf7 motherboard ram slots broken
Sorry, the board is toasted, that memory channel is dead.
Jun 15, 2010 | Abit NF7-S Motherboard
Hi. i have abit motherboard nf7 s2. i bought 2
Did you make sure to install the memory starting from DIMM3? You should install into DIMM3 then DIMM2 according to the NF7 manual.
Mar 14, 2010 | Abit nForce2 NF7-S2 Motherboard
Driver for motherboard abit nf7 - s2g
Open the Abit NF7-S2G link provied below and download the drivers located to the right of the page listed under, Support Information.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF7-S2G&fMTYPE=Socket+A
Cheers'
Mike
Mar 03, 2010 | Abit NF7-S2G Motherboard
Abit NF7-s v2- hynix ram support problem
your system does not support the dual ddr ram unless you have a add-on VGA card
I have included the link to the user manual ... see chapter 1 section 1-1 Features and Specifications
Abit NF7-S v2
Supports DDR 400 only when using an add-on VGA card (NF7-M)
Feb 13, 2010 | Abit NF7-S V2 Motherboard
NF7-S2 No POST on startup. Can Not get into Bios
In that case the motherboard itself is faulty replace it..
Jun 08, 2009 | Abit nForce2 NF7-S2 Motherboard
Abit nf7-s rev2 not posting. Cleared CMOS, pulled out battery for 20 minutes & replaced, checked wiring and memory seating, checked graphics card and CPU in a different board and they worked ok. Im getting...
Have you tried replacing the memory modules? Memory incompatability or a bad simm, will create the symptoms, you describe. Also, restore the BIOS settings to "fail-safe," if possible. Often the "Default settings," are not as "tolerant," as fail-safe. I had a similar issue with ASUS and LanParty motherboards. It was a bad SIMM.
Mar 09, 2009 | Computers & Internet
Need CD for support drivers & utilities Abit NF7
its here. copy n paste in ur browser and go to that page
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=nf7
Dec 29, 2008 | Abit NF7 Motherboard
Abit nForce2 NF7-S2 Motherboard Logo
223 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
