Question about Motorola Mobility V300
Can't hear caller speaking on phone
I have a motorola v300 that's 1 year old i cannot hear the person who is calling me but i can hear them if i put it on speakerphone. It has not been damaged by dropping as far as I know. Oh, and i'm not deaf, so no silly remarks please. It's not the most discrete way of having a phone conversation and its driving me to the point that it's going in the bin soon. I cannot find in the menus a setting that might be the cause of it.
  • 2 more comments
  • Anonymous Sep 02, 2008
    Same sort of problem as previous message
  • Anonymous Oct 04, 2008
    I can't hear the caller on my phone. Is there a mute setting on the V300's? I've quickly searched the manual but find nothing.
  • Anonymous Mar 31, 2009
    same here
  • arieschelle May 11, 2010
    anyone can help unlock my MMS and GPRS settings for my Motorola V300..?
    New Friend:
  • 163 Answers
Just in case check the volume during a reciving call, the volume control both, speaker and speakerphone, as it, you got a damage speaker, go to the celu store and ask for a repair, they have jonks to do it for cheap...good luck
Posted on Aug 07, 2006
SOURCE:
As the receptionist I take calls and then transfer them to the person the caller disires to speak with. For example, if I am on a call and the person I am speaking with would like to speak with my boss, I...
A couple of things, but first. When you TRANSFER a call to your boss using the transfer button, he key to getting rid of the call is to hang up. But that's not your problem. When we install voice mail systems, we reserve 3 buttons; one for VM TRANSFER, one for 2 WAY TRANSFER, and one for VM RECORD. It's easier to link you to the OM of a TDA system than explain it, so here's the link http://www.public.carl.airpost.net/Pana/TDA/200_TDA_OM_06-121.pdf
Pdf page 170 will give you the table for setting up your 94,91 and 90 codes for the above features.
Basically, you press PROGRAM, the button, and dial, for example, 94 500 SAVE to store the VMT . You use it by pressing that button while you on the call (no hold) and either dial your boss' extension or press his DSS button. If you use the 2-way transfer, you can actually put his number under one button and carry on a 2-way conversation with the outside party. Kind of like you would do with the old 'pink slip' messages.
Carl
Mar 16, 2011 | Panasonic KX-T7630 Corded Phone
Incoming caller ring
Here is the link to the user manual if you need it. http://www.motorola.com/Hellomoto/Master%20Lists/Product%20Manuals/Static%20Files/CA-EN/30277_E815EnglishUserGuide.pdf Unfortunately what callers hear is dependent on the phone they are calling from, not on your phone. You could concievably send them a mutimedia message when they call, but there is no way to automate this, and it would probably be too much trouble and expense to bother. Wait a year or two, and it may well be that manufacturers start including this feature - it would require a slight modification of the communications protocols on the cell networks, but it probably would be popular. Good idea. Hope this helps :)
Jul 10, 2007 | Motorola Mobility E815
Volume of my voice on Motorola V170 trakphone
the phone's Microphone or Microphone IC is faulty. replace the Mic its under this place. or even just clean it maybe some dust would defect it.
.please rate this post as good as u can so we can help others.
Feb 02, 2009 | Motorola Mobility RAZR V3
Can't hear caller but caller can hear me except on speakerphone
Take the phone to a mobile reapir center and hvae them replaced teh ear piece and also the speaker.
Oct 18, 2008 | Motorola Mobility RAZR V3i Cellular Phone
6230i - Callers cant hear me speaking
Make sure that the microphone is not in the mute mode. Read the instructions for your phone, or fish through the menus to find where the setup is for the microphone default if the phone has this option.
I have also seen the microphone go defective in these phones.
Jerry G.
May 25, 2008 | Nokia 6230
I can't hear caller unless speaker phone is on.
the speaker is in miscontact ..... if you are good at opening the handset then just open it and reconnect the apeaker correctly ...
if problem persists then try changing your speaker.....
remember i am not speaking about the loud speaker ....
your problem will get solved by doing this....
Feb 18, 2008 | Motorola Mobility RAZR V3
Can't hear caller's voice
Turn up the volume control.  Don't have the manual in front of me but go into phone settings and look for the volume settings( not the ringer).  Check in your manual, you'll find it.
Oct 23, 2007 | Motorola Mobility L6 Cellular Phone
Problem with heaing incoming and outgoing calls unless using speakerphone
I can't hear people that call me unless I put them on speaker phone. Called Motorola and they had me reset the phone but that did nothing. Any other suggestions?
Thanks.
May 30, 2007 | Motorola Mobility RAZR V3
Callers can't hear me speak
This is because the microphone in your phone got disconnected in some way. Probably a faulty contact. This is a known fault for some motorola phones. The solution would be to go to a service center and ask them to check your microphone. It isn't an expensive repair at all. They will be able to do this for you in about half hour or so. It is the safest way to do this, otherwise you will have to dissasemble the phone yourself and check the microphone.
Mar 12, 2007 | Motorola Mobility V265
Handset microphone not working? callers cannot hear me, i can hear them
Hi i also got this problem, when i went to the service centre, they told me that the whole circuit needs to be replaced along with the keyboard. It sounds costly to me.
Jan 22, 2007 | Motorola Mobility RAZR V3i SLVR L7 L8 OEM...
Motorola Mobility V300 Logo
135 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
