Question about Toshiba Satellite A135-S2276 Notebook
My web cam don't work with msn messenger
When put on it says conecting then disconect on its own
How to work the web cam.
connect you cam and install the driver for your cam and if you have any messenger installed login to your messenger and start your web cam. if you don't have internet connection for offline testing you can use msn messenger. Go to tools and options and web cam !!!!
Nov 26, 2010 | ASUS Eee 4G Notebook
Cam is not working of acer aspire ZG5
try to reinstall all of them
here's the link of your laptop driver
http://blogntech.com/download-acer-aspire-one-xp-driver.html
Jan 17, 2010 | Acer Aspire One PC Notebook
Laptop Cam not working in MSN
Please check the folloing in your msn messenger;
1.- file
2.- action
3.- video
4.- select show my web camera,
5.- select view contacter in the web
Your rating is very important to me...
was this helpful?
May 04, 2009 | Microsoft Windows Live Messanger
Dell webcam manager working with msn messenger?
if you have the webcam center opened along with with msn then it wont work on either one of them.
you can try these steps tp check if it works for you or not.
1)look for the web cam center system tray icon and right click on it if its there and select exit
and as u said u cant see you self in web cam console --- in webcam console you can only see your self under the doodling tab and only of your webcam is working at that i.e
either you have the webcam center opened or any other messenger or software which turns on your cam then only ull be able to view your cam in webcam console alongside.
Apr 28, 2009 | Dell XPS M1530 Laptop
Sony Vaoi built cam doest work on messenger
i have a gateway fx gameing laptop!! i was having probs with the cam going dark on me after a bit while using yahoo messenger..it was also freezing up but that i found out was cause yahoo SUCKS **** LOL...
i downloaded msn messenger, not msn live, and the cam works fine.. so it is yahoo.. i do know that sometimes my cam will sometimes go darker in resolution if i bend the top down a bit.. its doing that because the cam is thinking that im turning it off by shutting the laptop!
does the web cam work with the software it came with? can u turn it on and see urself when NOT using a messenger? if so then it might just not want to work with those 2 messengers which is weird!!!!!
MAKE SURE THAT U DO NOT HAVE THE PROGRAM SOFTWARE on that came with the laptop at the same time as trying to use it with the messengers!! see if that works and ill check back with you!
laptops did not come with the high end state of the art web cams! they were made for ease not for exceptional quality!
Mar 22, 2009 | Sony VAIO VGN-SZ430N/B Notebook
as ive told others, make sure u actually turn off the software program that came with the computer before using with msn! u should be able to have it on while using it but for some reason some computers wont allow it! it "tells itself" that there are 2 programs trying to run the web cam when really only one is.
but because the program is on, it sees it as being used in 2 places at 2 different times!
try turning off and exiting the software (dell webcam manager) and then go onto msn and try using ur web cam!! make sure the dell manager is exited, then when u have a msn window open, turn the cam on and see if ur friends can see u then..
good luck..
if this doesnt work ill check back and see what i can do for you!
Mar 21, 2009 | Dell Inspiron 530 Desktop Computer
Acer aspire 5520 crystal eye cam
in this case the problem is with the msn...try to reinstall the windows live messenger ...there are available new updates on windows site ...just google for windows live messenger ..and it will gave you solutions for download
so ..reinstall cause it it was the camera..it should just not work ...but you should be able to see other people web cams..
Mar 16, 2009 | Acer Aspire 5500 5570-2609 Laptop
My webcamera doesnt work when i open my msn messenger,
u have to install driver of ur web cam....then in the setting of MSN messanger u should select ur caputering device (ur web cam model)then aplly...MSN will connect to ur webcam
Mar 08, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
Web cam
In msn live click on show menu then tools option for cam setup
If that don't work click again show menu then actions then video then show my webcam or start video conversation.
If taht does'nt work then I would assume it's something in your camera setup itself
Jan 11, 2009 | Acer Aspire 5610-4648 Notebook
Philips spc 700nc web cam
First of all, have you verified you are using latest version of MSN messenger. If so and the problem still exists, give one of the other instant messengers a try, say like YM or AIM or any number of others.
What exactly do you mean by ' seems to work '?? Can you see yourself in the cam using whatever software other then MSN that you may have on your computer.
Feb 20, 2008 | Philips SPC700NC Webcam
Toshiba Satellite A135-S2276 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
