Question about Canon PowerShot A75 Digital Camera
No picture on screen
There is no picture coming up on the screen..the camera acts as if its working ,,the flash works..just not the screen.....also the quality of the picture has been bad before ,,now there is no picture
  • 10,594 Answers
Your Canon A75 camera has problem of CCD Imager sensor and this part will be replaced.
Canon has announced scheme of free of cost repair for such problem in A75 model. Click Canon CCD Advisory to see details.
Thank you.
Posted on Oct 23, 2008
Will not take a picture or video
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 27, 2009 | Canon PowerShot A85 Digital Camera
Powershot s200 digital elph 2.0 black screen
CCD failure but u are LUCKY just contact canon they will repair free of charge even if u are out of warranty dont worry and i deserve FIXYA rating for this
see these links below
http://www.imaging-resource.com/badccds.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
Dec 14, 2008 | Canon PowerShot SD110 / IXUS IIs Digital...
Sonyy w55 flash works but shot come really dark
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
Aug 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Lcd black while in picture taking mode
Your ccd appears to be bad. Canon USA will repair this for free. Go here for details. They will send you 2 emails. One with the UPS label and another with info sheets to be sent with the defective camera
May 28, 2008 | Canon PowerShot A75 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
Flash for Coolpix L6 Digital
You can try to reset all of the internal settings. This has worked for me with a digital camera.
It would be good here to know what kind of camera we are working with.
Make sure you do not have any of the settings in the camera set to turn off the flash...for instance setting it at mountains or most any outside setting may not allow the flash to work. Some cameras will allow you to override the setting internally.
If the flash does not work at all, then repairs will be needed.
Dec 18, 2007 | Nikon COOLPIX L3 Digital Camera
Camera acting strange.
i have the same problem. wat did u end up doing with it?
Nov 04, 2007 | Olympus FE-210 Digital Camera
My Canon A95 flashes on its screen and i couldn't take any pictures...
Really it does sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
Jul 29, 2007 | Canon PowerShot A95 Digital Camera
Cannot take pictures
cannot take a picture the lcd is on blank screen
Jul 14, 2007 | Kodak EasyShare CX4310 Digital Camera
Canon powershot SD 100 - I can't see anything but a black screen
This problem is caused by a stuck shutter assembly. Normally the shutter is open which allows light to enter the image sensor and show you the live preview you see on the screen. When you take a picture the shutter closes which allows the image sensor to record what was seen at the exact moment the shutter closed. The shutter is stuck closed, causing the image sensor to always be in the dark. These shutter assemblies are extremely small and delicate. The miniature parts can become jammed with just the slightest bit of oil or contaminant, or the slightest misalignment of components. The problem can sometimes be fixed by gentle tapping of the camera on a solid surface. If you are going to try this be VERY careful, and do not tap the camera on the buttons, lens, or battery door. If this does not solve your problem then the camera is going to have to be taken apart and the shutter cleaned and reset to allow free movement. This repair costs $125 to $145.
Apr 22, 2007 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot A75 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
