Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
How can i configure Linksys Wireless range extender
I want configure linksys wireless range extender with secure network.
  • 59 Answers
Hi ,
i went through the problem ur facing and the only solution that comes into my mind is that u will have to do the wireless settings on the router and copy the same settings on the range expander as well .... no changes.... and do remember that range expander at that time should be connected to the router at that time with the help of an ethrnet cable .....
ity would be working like a horse then ...
Posted on Oct 25, 2008
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
I want to secure an unsecured linksys router
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 19, 2013 | Linksys Computers & Internet
Cant find a strong enough connection
You need to buy a Linksys Wireless-G Range Expander to boost the signal
  • Move your wireless router to a central location in your network, keeping in mind that the router should be at waist level at the very least, not on the ground.
  • Plug in the Linksys Wireless-G Range Expander in the room where your wireless router is. You'll move the range expander later, but for setup purposes, it should be in the same location as your wireless router.
  • Press the Linksys Wireless-G Range Expander's "Auto Configuration" button for five seconds, which will allow the range expander to detect your wireless network and configure itself with the appropriate settings.
  • Unplug the Linksys Wireless-G Range Expander and relocate it to a location closer to the Xbox 360.
  • Ensure that the antenna for the Linksys Wireless-G Range Expander is pointing upward, and keep in mind that the higher the range expander is placed, the better performance you will get out of it.
  • Plug the Linksys Wireless-G Range Expander back in, and your wireless network should have a much greater range, ensuring that your Xbox 360 is able to maintain a good connection to the network.
  • Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
    Hi, I just got Linksys WRE54G V.3 and was trying to install the CD. But I keep getting "Site Survey fail" message. My house is using a router made by Apple, and does not have extra space to...
    The range expander helps to extend the range of wireless network...
    Anyhow the range expander has to be placed withing the range of your Apple "wireless" router (Make sure your apple router is wireless router, if it is a wired router, then there is no use of range expander...! U need to buy an Access Point instead)...
    your range expander must be connected to the computer(using an ethernet cable) from which you are trying to configure...
    Site survey searches for the available wireless networks in range...
    It should show your existing wireless network...
    You need to select your appropriate network and you need to configure the Range expander wireless settings according to the Apple router's wireless settings...
    exactly the same SSID(Network name), Security type and encryption technique, password PSK (security key) has to be selected on your range expander as in the APPLE wireless router...
    Thats it...
    You are done...
    Your wireless network range would have extended now....
    Dec 09, 2010 | Linksys Wireless-G Range Expander (WRE54G)
    Lost installation cd cant connect to wireless router wrt54g v8 linksys router need to know how to get it connected to my laptop
    If you configure the Linksys wireless router with encryption and you configure your wireless card in your computer with the router's encryption settings it will secure the Linksys wireless router and allow your computer to connect to the Linksys. Please click on this link and follow my instructions to secure your wireless router :-
    Jan 06, 2010 | Linksys Wireless-G WRT54G Router
    I am running qwest DSL through a Linksys wrt160N that is brand new. it will work next to the router, but not upstairs or in the basement which is less than 15 meters. The upstairs bedroom is directly above...
    If you have concrete floor slabs the the wireless signal from the Linksys will have a difficult time penetrating the floor slabs.
    The wireless card in the computers will show a low signal strength.
    Try altering the Linksys aerial to a horizontal position and also positioning the Linksys to another location.
    You could be getting interference form other wireless sources, check the wireless channels of other wireless router/access points in your area. If they are broadcasting on the same channel then configure your Linksys to broadcast on an unused channel or one that has the weakest signal strength.
    If none of these methods work then I would suggest you run network cables from the Linksys to upstairs and downstairs and not use the wireless connection.
    If network cabling option is not an option then consider extending the wireless range with wireless repeater access points.
    Nov 07, 2009 | Linksys WRT160N Wireless Router
    Wireless g range extender
    Hi there ....
    before anything else, can you please what is the version of range expander is is wre54g v1,v2,v3?
    1) either which, please do verify your wireless settings of your DLINK router
    -- the network name or ssid
    -- security if you enabled any on your router
    -- wireless channel
    -- please check the default gateway of your router if it is 192.168.1.1
    ** please take note also that the best location for your expander would be inbetween your router and your computers
    2) once you have gathered the wireless settings
    -- you would need to manually configure your expander coz it didnt work .. Please remember that the LINKsys expander is designed to work with linksys routers, so it may or may not work.. I just need to set your expectations on this ...
    3) once you have verfied the default gateway of your DLink router ... please reply to this thread and let us proceed in configuring your wre...
    Thanks and good luck!
    Oct 31, 2008 | Linksys : WRE54G Wireless Range Extender...
    Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
    271 people viewed this question
    Top Belkin Computers & Internet Experts
    Prashant M
    Prashant M
    steve morris
    steve morris
    Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
