Question about Haier HVTS16ASS Wine Cooler
It does not cool, and the temperature stays on 80, it won't go down
Fan won't stay running and temperature sensor flashes
Sounds like the fan needs replacement. A faulty fan will shut the set down and the tem light will falsh in most cases.
Oct 27, 2012 | Televison & Video
I have a 1988 Dodge Dynasty that acts like it's vapor locking.
yes fuel pump is dying (it's old ) it will finnaly give up the ghost some day soon then engine won't run at all
common problem pump heats up and shuts off cools off and runs again cyclic
this all assumes you have kept up on changing the fuel filter at reg intervals too
Jun 14, 2012 | 1988 Dodge Dynasty
I turn the top oven on and it won't stay on.
your laptop bakes things? you may want to consider a cooling pad.
May 09, 2012 | Computers & Internet
My air conditioner won't cool down
I Think when it goes back to 33 thats your ambient temp . the temp in the room thats its trying to get down to .
If you set it on 22 . and just ignore the 33 it does it stay on cooling ?
Jan 30, 2012 | Heating & Cooling
I had a white rodgers thermosat system & its digital. I dont what model # it is but I want to know should I have the temperature set low or high if its 80 degrees in the house?
The set temperature is the temperature you want the system to cool the inside of the house.
A lot of digital thermostat will display the current ambient temperature. When you push the set temperature up or down buttons the thermostat will display the set temperature momentarily and will change if you push the up or down button.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
I'm having a problem with my thermostat reading much higher than set temperature. The apartment manager is blaming the heat outside, but I've been here 3 years and this is the first time I've...
Hello my name is Heath it will be my pleasure to assist you. The thermostat is bad and will need to be replaced the heat anticipator in the thermostat has gone bad. I would replace the thermostat.
Aug 08, 2011 | Heating & Cooling
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
Set at 75 but stays at 80 and won't cool down until night time.
Sounds like you're low on refrigerant. You might try to measure the room temperature and the temperature coming out of the grill. The temperature coming out of the grill should be about 20° lower than the room temperature. For instance if the room temperature is 80°, then the temperature coming out of the griil should be about 60°.
May 07, 2010 | Honeywell Electronic Programmable...
Haier HVTS16ASS Wine Cooler Logo
73 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
