Question about Nikon Coolpix 4100 Digital Camera
Lens stuck and I cant get the camera turned on. I have a nikon coolpix s4100
What can I do to get the lens unstuck? Its definitely not a battery prob becuase the battery was only down by half
  • 734 Answers
Low battery voltage left the lens in a position that the electronic circuit can not resume the next operation. Its a typical Nikon digital camera problem. The tolerance on the lens barrel maybe too tight. The solution maybe replace the lens assembly.
Posted on Feb 11, 2012
  • 11967 Answers
SOURCE: Nikon coolpix s202 shows lens error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 28, 2010
SOURCE: nikon coolpix l12 lens error
Power on camera then push firmly on shutter lens and it should retract. Worked for me.
Posted on Apr 13, 2008
SOURCE: lens is stuck open says
when the camera is turned on it displays "lens error". I can't take a picture and i can't access my pictures on the camera.
Posted on Nov 08, 2008
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Posted on Mar 29, 2010
  • 11967 Answers
SOURCE: camera's lens is stuck
Posted on Apr 23, 2010
How do I get the SDGC 8GB memory card to work for my Nikon s4100 coolpix camera?
You may need to format the card prior to first use. This should be in the menu system somewhere. Your manual should point you in the right direction.
Jan 09, 2016 | Nikon COOLPIX S4100 14 MP Digital Camera...
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
How do I get the shutter to open and close
If the Lens doesn't go in and out, The front covers will not open, Sound like the lens is damaged, Not cost efictive to repair.
Oct 14, 2014 | Nikon COOLPIX S4100 14 MP Digital Camera...
My nikon coolpix s220 does not turn on and the lens just got stuck up.
you should take out the camera battery.and remember do not touch the lens or correct it.because it will damage the lens in a further step. then send it to the maintance center
http://www.digitalcamera-parts.net/
www.skiliwah.cn/
e-mail:e-8090team@hotmail.com
Aug 31, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon coolpix L11 Lens stuck
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Sep 28, 2009 | Nikon Coolpix L11 Digital Camera
My 9 month old camera (Nikon s210 coolpix 8.0mp) that I
Hi!
It sounds like the lens focus is stuck. If you don't have experience in camera repairs, you should give it for a repair to your local Nikon service center or other camera service center.
Tom
Jul 31, 2009 | Nikon Coolpix S210 Digital Camera
Nikon lens 18--55mm stuck
Dropping is the most common cause or a knock whilst whilst the lens is out.
Dirt ingress is another possibilty.
It is almost always physical damage - or a low battery.
There is- as always this out of warranty items of this class no repair opportunity
Jul 27, 2008 | Nikon COOLPIX L3 Digital Camera
How can i fix a stuck lens on a Nikon COOLPIX L11?
I have the same problem with my nikon coolpix s200. After 2 months the lens of my camera won't go inside. On the lcd screen stood lens error. I went to a shop with this problem. He took the battery out of my camera and press the off and on button for a while. Then he put the battery back in the camera and press the on button. The lens of the camera was now going inside en outside and inside and outside with a strange noise. And also on the screen stood lens error. Okey, the lens is inside the camera. But how can I fix this camera? What is the problem? What have you done? Please let know..!!
Jul 13, 2008 | Nikon COOLPIX S200 Digital Camera
Camera lens will not close
Hi:
Sometimes you can try to get it unstuck by looking at the lens at is is. Then determine if it appears to be at a slight angle, if so, it may be that you can force the lens in the opposite direction. This may not work, and may damage the lens further, however, since it is not working, trying may be just what is needed.
I have had some success by forcing the lens in the opposite direction as it is turned on with pressure of my fingers pushing it. It has not always worked, but I have two which worked just fine... one was a 7.1mpxl nikon and the other was a 8mpxl Canon.
They both were off track, and jumped back by a little force.
If the lens was hit or dropped, then damage can be more than can be fixed. What can happen is that the small track parts can be broken, then there is no way to get it back on track.
Also, dirt or sand can do a number on these small parts. It is amazing how these extremely small pieces of sand can jam a lens, but I have seen it happen.
Take a hint and keep the camera away from sand and water, or risk trouble.
Jun 11, 2008 | Nikon COOLPIX L3 Digital Camera
Nikon Coolpix S5 lens cover won't open
Hi Debscan, My 1.4 year old S5 developed the same problem and after checking out various websites I get the impression that it is a common one to these cameras. I found that if I put the camera on a level table and then turn it on (and off) 3 times the lens cover would open further with each try. On the third turn-on the lens cover would drop fully with a definite "Click" and the camera would work. The next time I shut it off, the lens would not close properly, but the same "Third times the charm" routine would always work. This may only delay the inevidable final crash of the camera, but it might get you a few more pictures out of it.
May 22, 2007 | Nikon COOLPIX S5 Digital Camera
Nikon Coolpix 4100 Digital Camera Logo
648 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
