Question about Kenmore 6.6 cu. ft. / 187 liter Chest Freezer 13601
Model 18313601300 6.6 cu. ft. chest freezer - Kenmore 6.6 cu. ft. / 187 liter Chest Freezer 13601
  • 833 Answers
SOURCE: Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Posted on Dec 04, 2007
hotuna
  • 288 Answers
SOURCE: 15 cu. ft. chest freezer
Remove the back panel, if there is one, find the compressor. Put your hand on it. If its very hot, you have a problem. You should feel a slight vibration if good and running. If The overload is shutting off keep your hand there and wait a few minutes, see if there is a clicking noise coming from the compressor. This is just a start, but you said it has been off for a while so my first suspect is a compressor. Do these things and let me know for a follow up.
Posted on Dec 20, 2007
  • 68 Answers
SOURCE: my kenmore freezer does not turn on at all
u either need a new thermostat or your compressor is dead
Posted on May 02, 2009
hiltonjug
  • 612 Answers
SOURCE: I have a Kenmore coldspot 16 cu ft chest freezer
It might have. Most likely you can start it again, but you will have to follow my instructions carefully. If you are willing, I'll tell you how to check it to see it it's bad and if not how to make it start again.
You will need a Ohm. meter and it will help if you know just a little about using it. If you do, gain access to the compressor. You will see where the wires go to it. The wires are connected to a piece or two that connects to your compressor. After unplugging your freezer, pull the parts off that are attached to the compressor. Now you will see three small metal pins sticking out of the compressor. Take your ohm meter, touch one lead from it to one of the pins and take the other lead and touch it to ground or somewhere on the copper tubing. If you have a reading, the compressor is grounded meaning it's bad. If yo have no reading. Take a lead and touch it to one of the pins while you are touching the other lead to another pin. It makes no difference which tow of the three your touching. If the compressor is good you should have a reading. Jot it down. Now move only one of the leads to the pin you have not touched yet. Jot that reading down if you have one. Now move the last lead you just moved and touch it back on the pin you started touching it to and move the other lead to the pin you just moved the other from. Jot that reading down. If the compressor is good, you first will have a reading each time you were to jot one down. Now look at you numbers you jotted down. The two smallest readings should add up to the largest reading if not exact it should be real close. If so, we can restart your compressor. You will need a Supco 3 in 1. You can get one from www.appliancepartsonline.com the part number is RCO410. It cost $21.95 plus shipping. The packaging will have the instructions on it. What you will do is gather all the parts that you pulled off the compressor. Cut them off. You should end up with only two wires. The 3 in 1 will have two Black wires that you will connect together with the supplied wire not. There will be three wires with ends on them coming off the 3 in 1 also. they will be White, Red and Black. Follow the color coded instructions on package. When you have completed these steps. Plug your freezer in. The compressor will start and run. The closer the numbers you added before where, most likely the longer the compressor will last.
Please rate solution.
Posted on Sep 09, 2009
jumptrout51
  • 3361 Answers
SOURCE: my kenmore 19.7 cu.ft. chest freezer is not
Place a volt meter set for amp draw around one wire of the compressor. If you do not have a constant amp draw replace the start relay on the compressor.
If you do have a constant amp draw the compressor is bad or you have a refrigerant leak.
Posted on Apr 25, 2010
Testimonial: "Thanks 4 the help. told me what i needeto know"
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
WHAT IS THE PRICE OF THIS MCCFFW CHEST FREEZER
spacer.gif 5.5 Cu. Ft. Chest Freezer bbd4a981-a436-4ad6-b98a-7249ef5d1d1a_300.jpg Click to Enlarge Lowest price:$179.00Description:
Food storage will be a snap with this roomy 5.5 cu. ft. chest freezer, featuring up-front temperature control, storage basket and defrost water drain.
Brand: Magic Chef
Category:
Appliances > Refrigerators & Freezers > Freezers > Chest
UPC: 665679002023
Model Number: MCCF5WBX
Dec 16, 2010 | Magic Chef Chest Freezer MCCF5WBX
The ice cream gets to hard and we have to take the big cartons out for 2 hrs before we can scoop it. (How can we bring the tempreture up about 10 or 15 deg.?)We can't find any controls on it. We have no...
Hi, I think you have tell wrong model . Please try find out the temperature controller. Your freezer should able to adjust temperature from 0 - 18 Deg. F
Chest freezer of caravell has 2 model i.e :
1. Caravell SST-5213.7 cu ft Chest Freezer With Solid Sliding Doors
  • Durable white powder coated, baked on enamel finish
  • Solid sliding top doors
  • Cord and plug included
  • Self-contained refrigeration system
  • Temp. range 0 to -18 degrees F
  • 13.7 cu ft capacity
  • Heavy duty casters included
  • Dual drain plugs for easy cleaning
  • Environmentally friendly CFC-free R-134a refrigerant and insulation
  • 115V, 4.5 Amps
  • 51 1/2"W X 25 3/4"D x 34 3/4"H
  • One year parts, 90 days labor warranty plus 3 year compressor warranty
  • & 2. Caravell GST-5213.7 cu ft Chest Freezer With Glass Sliding Doors
  • 115V, 4.5 Amps
  • Regards, jay
    Nov 30, 2010 | Caravell 13.7 cu. ft. / 388 liter Chest...
    We have a 21 cu ft 2009 chest freezer. It is not
    Is your circulating fan working?
    Sometimes they stick and need a shot of WD 40 and then work
    it back and forth a little until it wants to take off again. Keep me informed
    and PLEASE give a Thumbs Up for the effort. The Raz Shack
    Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
    My kenmore freezer does not turn on at all
    Nov 21, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
    Kenmore 6.6 cu. ft. / 187 liter Chest Freezer 13601 Logo
    67 people viewed this question
    Top Kenmore Freezers Experts
    Charles T Nevin
    Charles T Nevin
    AJMAL KHAN
    christian nielsen
    Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
