Question about Polaroid FLM-2011 Television
Polaroid Television My picture has a green tint. I tried to adjust the picture through the Menu - didn't work. Any idea how to adjust the picture?
  • mrbarg Oct 27, 2008
    I have a serious blue tint to everything on the screen and can not get rid of it. If watching a movie with sunshining on someone's face in the film.....that part of the face dissappears into a white out effect.
    Anyone know how to fix this, already tried all the menu options several times in severl different combinations.
    Thanks for your help
    Jonny B.
    Marysville, WA
    Problem Solver:
  • 6 Answers
Green tint is often replated to faulty lcd loom cable open unit power up and jiggle the loom cable a multi stranded connecting cable...this cable often gets corrosion on the pins..if this is the problem spray lightly with anti corrosive lubricating spray eg q20 or other use a cable tie to resecure this loom tightly to a nearby post etc to apply tension to this cable...or replace this loom if faulty refer to local service agents.
Posted on Aug 01, 2009
Green tint on picture. Cant adjust with tint or color from menu
My rear projection was doing the same thing. I have a mitsubishi and went into the video/audio set up. When I clicked on video it brought up brightness, tint, color, etc... Not sure if yours is set up the same.
Jan 18, 2011 | Zenith E44W46LCD 44" Rear Projection...
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Picture has green tint
use menu on remote adjust tint to center
Mar 23, 2008 | Philips 9P5034C 50" Rear Projection...
Green Tint in HDTV for the first few minutes.
Possibly adjustments to the service menu could rectify this. Also, adjustments must be made to customer settings in menu for each input. In the past I have improved or solved this by making service adjustments, however, if you attempt this, please make sure you know what you are changing and make sure you are in 1080i mode. Service code (mute,1,8,2,power on)vol+ and vol- to select an item. Use mute and the menu to adjust. Use add to save the settings. Take your time. Hope this helps.
Mar 11, 2008 | Samsung HCL5515W 55" Rear Projection...
Polaroid FLM-2011 Television Logo
88 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
