Question about Microwave Ovens
Microwave fan won't turn off?
I woke this morning to the power flickering then the vent fan for the microwave (kenmore 8965580) turned on and wont shut off. The weird thing is that the fan hasnt worked in years. everything else works fine heats and all. The fan buttons dont work and the only way i can turn it off is to shut the breaker off. Any help. thanks brian
  • 46 Answers
Hi i would think that the power problem has fried the processor
cheers grant
Posted on Oct 23, 2008
My microwave oven model 721.85033111 vent fan stays on
You probably have a bad fan thermostat. This thermostat is supposed to turn on the vent fan if the microwave oven gets too hot (caused by cooking too much or having too many burners turned on on the range beneath the microwave oven). It should shut off in about 15 minutes after your turn off the range burners. But if it comes on for no reason, or won't turn off, then You probably have a bad fan thermostat.
Aug 10, 2014 | Kenmore Microwave Ovens
Vent fan wont turn off
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
Apr 22, 2014 | Maytag Over-the-Range Microwave
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
Vent blower won't stop
I had the same problem with the fan not wanting to shut off after the repair. Once I set the clock though I was able to push the button to shut the fan off. So try setting your clock first and see if that helps.
May 07, 2013 | GE Profile Spacemaker Over-the-Range...
We have a kenmore ultra wave microwave and the fan has stopped working and now the microwave won't operate. Any suggestions?
see this causes and fix it .God bless you
Exhaust Fan Motor If the exhaust fan does not run the fan motor might be bad. Remove the fan motor from the microwave oven and see if the blades can be turned by hand. They should turn very freely, if they're stiff the fan motor will need to be replaced. The fan motor can also burn out. To test this use an Ohm meter. The motor should have continuity. If it does
Thermostat If the microwave exhaust fan is not working the thermostat might be defective. The thermostat senses the air temperature and turns on the fan as needed, if it's defective it won't turn on the fan. Watch our video on testing thermostats.
Main Control Board If the microwave exhaust fan is not working check the exhaust fan motor and wiring. If they are good the main control board might be defective.
Oct 02, 2012 | Microwave Ovens
Why won't my kenmore microwave's exhaust fan turn off?
It is more than likely one of the door switches has malfunctioned, or there is a problem with the keypad control board.
Apr 19, 2012 | Kenmore Microwave Ovens
Fan does not shut off unless unplugged
If the light and fan come on when the door is opened normally, check the door switches.
May 19, 2017 | Kenmore 80809 Microwave Oven
Cannot turn off fan
the fan has to stay on,thats the way they are made
Nov 30, 2008 | Kenmore 60654 Microwave Oven
My Microwave flickers and buzzes
This problem normaly happens when the door is not closed properly for a long time and flashing and buzzing starts to give user a indication for same. Allthough it is not risky as microwave oven has safty door switches wich does not allow oven to operate while door is open. Take care and close the door properly before you leave kitchen..
Aug 02, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
733 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
