Question about Balance CM2015 15" LCD Monitor
My Balance ICPower monitor, after coming out of sleep, just flashes continuously. The display and the power light.
I put my computer to sleep, and when I tried to get it awake, the monitor wouldn't come on; when it finally did, it just flashed. I can get it into Safe Mode, but it flashes so fast, I can't see to adjust anything. The computer is an emachine, and the monitor is a Balance model CM2015 15" (black). I tried it on another machine, but it does the same thing. Every time the screen flashes, the power light does too.
  • 198 Answers
SOURCE: CM2019 LCD MONITOR NO PICTURE
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Posted on Feb 20, 2008
  • 237 Answers
SOURCE: I need the display driver cm2015
http://members.driverguide.com/driver/detail.php?driverid=564775
I'm not sure where you found your driver, but this is from another website, hope itworks
Posted on Dec 13, 2008
thinstatic
  • 50 Answers
SOURCE: screen goes black
This indicates the LCD inverter in the display is dead. If you have any experience with computer repair, replacing an LCD Inverter can be easy enough; However, it may not be worth it for a 15" LCD; replacement inverters can cost anywhere between $15 and $40 - a decent used 15" LCD only costs about 40 bucks these days...
Posted on Feb 13, 2009
  • 152 Answers
SOURCE: Power failure issues
Father2gabe, Try this! With fully booted KNOWN GOOD pc displaying the win-desktop, reconnect suspect bad monitor to PC. Then and only then turn on the monitorand note what happens on screen. What happens if you point a bright flashlight (torch) at 2-4cm from screen??? Do you see the desktop screen even though the screen remains black?
Also do search on web to find out how lcd monitors get WHITE LIGHT to shine from the rear side to the front side!! Yes, your AC adapter must produce the same DC voltages as the original nonfunctional adapter-brick did!!! I would suspect that the VOLTAGE INVERTER BOARD inside the monitor is not now or will anytime soon, produce 800-1200v ac to light up the "cold-cathode-fluorescent-tubes" (CCFL's) that are hung horizontally across the glass LCD panel. Get back to me with result of flashlight test. louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 26, 2009
budmrtn
  • 11361 Answers
SOURCE: i have one Balance CM2015 (Black) 15" LCD Monitor
You do not really need the driver for the monitor for it to work with any PC, the only time you need the driver is when all the resolution are not listed when you try to adjust the resolution, it is really bad if you run windows 7 since a lot of companies will not provide windows 7 drivers for old monitors. You need to use Fn key combination with with either F4,5, 6, or 7 to select internal/external/both which depends on the make and model of the laptop.
The monitor work OK with desktop PC?
I repair hundreds of monitors and I would have gone crazy installing ALL the drivers for ALL the monitor I have to repair.
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 22, 2011
My monitor won't come out of sleep mode
when the computer enter the sleep mode, it is possible that the computer remove the check mark from this output activation.
When you have multiple ouptut like a internal LCD and output on a monitor, when going into sleep then waked up, laptop reactivate the internal LCD without reactivated the secondary monitor.
you could need to go in desktop property and reactivate the secondary monitor with the check mark listed : Activate.
If you only have one monitor but still a dual output card or two separate video card same thing can happend. try to connect the monitor on the second VGA or HDMI output and see if the video goes there.
then reactivate your secondary output and make it principal.
Does also happend when your computer is connected to a UPS power and your monitor is directly on the sector. (laptop issu also)
if a brief power outage arrive then the monitor shut down (no power) and the computer continu, as there is no monitor on the output any more Windows will automatically deactivate this monitor. when power goes back, this output is no longuer providing video. I suggest putting the monitor on a UPS as well.
Jan 03, 2014 | Westinghouse Electric L1916HW 19" Monitor
Moniter will not come out of sleep mode
It sounds like the unit is not really in sleep mode, a flashing power light and no display is a common indication of a failure of the power supply board. This type of problem is very common on LCD monitors. There are parts called filter capacitors that overheat and fail which cause the power supply to not be able to start up correctly so you get the flashing power light and no display. The power boards are repairable, it requires just a little soldering to replace the bad capacitors. You can get a kit of the parts here: http://www.ccl-la.com/catalog/product_info.php?products_id=343
I hope this helps,
BuddyMc
Aug 07, 2013 | ViewSonic VX2245WM LCD Monitor
I have a acer.x223w when,it powers up the.screem stays black, n i get a blue blinking light on.the bottom
I disagree with ikkenom only due to the symptom of the flashing blue light. This would indicate to me that the monitor is not getting any display signal and is in sleep mode at least the is what happens on my Samsung monitor. Used to be that they use a two color led in the monitor, green when ON and getting display signal and amber or orange when in sleep mode. I would check the computer by trying a different monitor. If you have a second monitor, great, if not, maybe a friend will let you bring your computer over and try the computer with their monitor. Could also be a display adapter setting. Do you get any change when you first turn on your computer? i.e. Do you get the BIOS or manufacturer screen when first turned on? Also if you disconnect the monitor cable from the computer and power cycle the monitor, do you get a No Signal display for a few seconds before the monitor goes black and the blue light starts flashing?
Let me know what happens with the testing above or if you need further instructions to carry out testing.
Thanks, Jim
Feb 21, 2013 | Computers & Internet
Monitors goes to sleep when powering my PC
In My Computer, find the icon for Display and configure the energy saving features so that your monitor doesn't sleep as soon.
If you need more help, I will be more than happy to assist.
Apr 07, 2009 | Relisys RLT1720 17" LCD Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Monitor went to sleep and won't wake up
my monitor comes on for a few seconds and then shows monitor going to sleep and then it does. can you please help me as i really need my computer.
many thanks
barneytina
Aug 11, 2008 | Princeton Digital VL17151 17" Flat Panel...
Going to Sleep Displayed
I turned on my computer and the monitor displayed this message on the screen "going to sleep no input received". I checked the power cord and unplugged it, nothing. No lights are flashing or beeping sounds. The CPU is working just fine, anyone have any idea what to do
Aug 02, 2008 | HP vs19 (Silver) 19" LCD Monitor
LG Monitor L194WT - Indicator Lights Flashing
sorry - i posted my response at the original thread : )
Comment by ohms, posted on Jun 19, 2008
Definitely it is not your computer. When it was given the signal to go OFF, it did but like completely off.
Comment by ohms, posted on Jun 19, 2008Oh one more thing, if the monitor still exhibits same issue after setting your Power Options as displayed above,
check your warranty with that monitor and exercise it.
Yep u got it ! warranty or new monitor
Jun 19, 2008 | Computers & Internet
Monitor
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
Balance CM2015 15" LCD Monitor Logo
56 people viewed this question
Top Balance Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
