SOURCE: How to reset bios password
underneath the button cover (plastic cover over power button etc) there is sw1 4 switches ,
put them all to on the power laptop then off again put switches back to what they were then on again
and presto bios password is no more
SOURCE: how to reset the bios password on MPC transport x1000 laptop
the best way to remove a bios password is to have the bios reset by a program called "winternals" this can be done by any pc repair shop
SOURCE: Bios of laptop Acer Aspirinhe 9410 (reset the bios)
Hi...
To reset the bios you need to open your laptop you can see there a jumper which is there is a small name (CLRSCR means clear cmos)beside the jumper you need to get it and turn on your laptop with in 5 seconds then turn it off, after that you reinsert the jumper, then turn on your computer and see if there is a bios password. "good luck"
Regards
PCmania
SOURCE: How to open case Toshiba Satellite L355-s7905
While I am not familiar with this particular model, most Toshiba laptops I have encountered have the DC jack soldered to the motherboard. If it has become disconnected, then reconnecting it is quite possible, but does require some skill. If you do not already have experience with soldering and/or PC repair, I would suggest asking a friend or family member who does.
In addition, if the laptop is still under warranty, I would speak to Toshiba support, as this problem is sometimes covered. Just back up your data first!
