Question about Garden
Hpw130df Hose conections
My beco washing machine water hose adapter is
Check for rubber sealing washers at both ends!
Oct 19, 2014 | Washing Machines
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
Where do gas hose connections hookup from primer bulb to gas tank and carboratuer
The bulb pulls fuel from the carb, into the bulb and dumps it back to the tank, there is usually a long and a short connection on the back of the primer, the longer conection is the pressure side so this returns fuel back to the tank, the shorter conection is the suction side, so this goes to the carb conection nearest to the metering cover, this is usually a chrome plate secured with four screws. The fuel hose from the tank with the filter on the end goes to the other conection on the carb nearest to the alluminium pump cover.
Jul 28, 2011 | Garden
I had to replace the fuel lines on my Craftsman model 358798940 leaf blower and i'm not sure how they hook up on the carburetor, 1 line runs from the fuel tank fliter to the carburetor and the other...
The fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, the other conection on the carb has a hose to the short conection on the back of the primer ( the suction side ) the longer conection on the primer ( pressure side ) has a hose back to the tank, this pipe just pushes into the top of the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank, not the other way round.
May 31, 2011 | Garden
How to conect fuel lines to poulan chain saw 2375 Le
The hose coming from the fuel tank with the filter on the end goes to the fuel inlet on the carb, this is the conection closest to the alloy pump cover held with a single screw, now take a hose from the other conection on the carb to the shorter ( suction side ) conection on the back of the primer, take a hose from the longer conection ( pressure side ) on the primer back to tank, this just pushes into the tank, just remember that the primer pulls fuel from the carb and dumps it back to tank.
Apr 14, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Maytag performa not recognizing when to stop filling with water
be sure the rubber hose runnig from the water level switch to the tub is conected on both ends if not conected to the tub the water will come out the hole the hose is supposed to be conected to and it want stop filling.
Jan 21, 2009 | Maytag Washing Machines
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
