Try with a different SMPS to begin with if still faces issue clean the dust accumalated between cpu fan and heatsink as some motherboard automatically cuts off power when temperature of processer exceeds certain level. if still faces issue remove the ram chip and power it on without the same and see if you can see cpu fan staying on for quite a while if yes ram may be the cause please note as ram is not connected you will not see any display but this process is used for testing. if nothing works try to unplug the 2 small power switch connectors that connect the power switch on the ATX cabinet and the atx power pins on the motherboard and then short the power switch pins on the motherboard with a insulated screwdriver to power it up and see if it stays on, if yes the power switch is causing the issue. please reply with results.
