Question about Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan
Hampton Bay Model EF 200-36 Ceiling Fan
I'm trying to find a hanger bracket for this fan (I bought it used). I believe the part number is H-13 but cannot find it anywhere. Not only does the fan hang from it but it also has an outer ring onto which the cap (that covers the wires, etc) attaches to.
Thanks!
  • Anonymous May 22, 2009
    Need H13 part. where to find it how to get it ?
  • fireroc302 Apr 10, 2010
    i am triying to find a remote add on for a hampton bay san marino 36" ceiling fan
Where can i find a hanger bracket for Model 42-cl?
Try Switchco at 1-800-365-4548, they have a few styles of hangers. Maybe they can help you. Can't hurt to ask.
May 04, 2014 | Encon Industries (78018) Ceiling Fan
Move existing ceiling fan to another location
make sure light switch is off.
start by unscrewing the fan blades. take out bulbs and bulb covers etc.
once all thats down the fan and light switch cover has three screws you can take out and unplug it to get it out of the way. look around the base for some more screws to take out and remove the big cover thats covering the motor. get it out of the way. now you will see the bracket thats holding the motor in place. remove them screws and bolts, but be careful and ready, the motor is heavy, and as it comes down, normally hamptom bay has a coat hanger type hook that will let you hook the hanging motor on the hook long enuff to disconnect the wires ONE AT AT TIME and then put the wire nut back on it just for safety. when they are all disconnected , you can un hang the motor , and then inspect the new fan bracket, it probably fits the same hanger. but if not, you need to take the bracket motor hangar down and get the wires out of it. if the light switch is off IT WONT SHOCK YOU. just dont touch the bare wires to your hands ANYWAY. if they touch each other thats ok. IF THE WALL SWITCH IS OFF. ok now its removed.
Jul 31, 2010 | Hampton Bay 24002 Ceiling Fan
Missing bracket to mount fan to electric outlet box
They sell universal fan hanger brackets at home depot for a few dollars. they will be in the same section as the lamp parts.
Sep 06, 2009 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
Do not have room for a remote control receiver in my ceiling fan. Can i just buy a new hanger bracket that has the mounting room.
Hello, your installation will determine if you can use another type of hanging bracket. If you require that the fan must be mounted close to the ceiling there might be a way to install the remote by using plastic wire ties to sucure the receiver. There are many fans that state NOT FOR USE WITH REMOTE. Please check to see if your fan is one of thoes. If ceiling height is not a issue then a new hanger bracket should do the trick. Make sure that the bracket and the installation location will support the weight of your fan. SAFETY FIRST
Aug 25, 2009 | Dryers
No outlet box in ceiling, it has a hook is there a special bracket, my home was built in the 1940s and the ceiling fan in the kitchen was hung with a hookin the ceiling, there is no electrical outlet in...
They sell brackets at home stores, but I have nailed a 2x4 between ceiling joists & mounted an electrical box at proper height. If you aren't good with electrical, get an electrican to run power for you.
The hanger must be SOLID & the wiring GOOD.
Apr 25, 2009 | Hampton Bay 42 In. Antique Brass...
Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Apr 19, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan or light goes on sporadically by itself.
It could be that a neighbor has a ceiling fan with the same CODE that yours is set at. It does actually occur.
Try setting the REMOTE(Transmitter) AND the RECEIVER, located tucked in among the electrical wiring inside the CANOPY which is also called the 'Hanger Bracket', to a different but SAME CODE for each device. The RECEIVER, which will have four 'dip switches', as does the REMOTE, will be a small rectangular box with a short antenna from one end.
Good luck. :)
Apr 04, 2009 | Hunter 52" Ceiling Fan With Light And...
Help me fixe my ceiling fans
Start over again!
Make sure that the HANGER BRACKET is properly and securely attached to the ceiling joists.
Then make sure that the HANGER BALL of the fixture is properly seated in the HANGER BRACKET.
Make sure the SUPPORT PIN is properly seated in the grooves in the top of the hanger ball.
Make sure that ALL the BLADES are firmly SECURED with TIGHT screws both at the BLADE ARMS AND at the MOTOR.
Remove the BALANCING WEIGHTS from the blades.
Make sure that the DOWN-ROD is indeed VERTICAL and not BINDING.
Turn on the fan in the SLOW mode and let it operate for a few minutes. Is the "shake and noise" issue still present? If NOT, turn it to 'medium speed and if still no problem turn it to high speed.
However, If the problem is STILL present, turn the fan OFF. Look closely and carefully at the LEVEL of the blades. You should be able to determine if one or more of the blades appears to be out of level. Use the minimum amount of balancing weight on the blades, and not every blade may need a weight. You do not want to contribute to the problem here.
If, after you have gone through all of the steps suggested here, the problem persists, then you have done about all you can do as a consumer to make this fan operate satisfactorily.
DOCUMENT the actions you have taken in an effort to remedy the issue on your own.
At this point load it up and return it to the place you purchased it for replacement or refund.
Good luck. :)
Mar 22, 2009 | Hunter 23852 Classic Original Ceiling Fan
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan Logo
915 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Fan Fair Of Boca
Fan Fair Of Boca
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
