Question about Sharp Digital Imager AR-407 Black and White Copier
Sharp copier ar-407 with h4-00 error code
Turn on and get this error code what is the fix
  • 120 Answers
SOURCE: SHARP AR C250 Digital Color COPIER HAS SERVICE CODE H4 00
Press P-interrupt-C-interrupt and enter test command 14 and Execute to clear your error. Let your machine reboot. If it comes back you have a problem with your fuser. Most likely it's dirt or toner caked on your tempature sensors and they need to be scraped off.
Posted on Jun 15, 2008
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
  • 990 Answers
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Posted on Apr 28, 2009
  • 7 Answers
SOURCE: I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Posted on Jun 10, 2009
  • 118 Answers
SOURCE: Sharp AR-M450 is showing error code ''H4-00''
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
Posted on Aug 21, 2009
Fix error code H5-02
fuser problem check it.
Oct 13, 2013 | Sharp AR-407 Copier
How to fix Sharp Ar-407 Code F2
There are a lot of choices for F2-?? Hold down the Start button to see the remaining digits.
Sim 22-6 will print all jam codes & error codes. It should be a process control code. F2-31 or F2-37, Drum mark or image density. You can execute 44-6. This should show which is out of range. Pull the drum unit out & clean both sensors. Check that the blade is cleaning from end to end that the DM is visible to the sensor.
Dec 26, 2010 | Sharp AR-407 Copier
H5-02 error and how to fix it.
input code 14 and press copykey
May 25, 2010 | Sharp AR-407 Copier
Sharp ar 407
Apr 28, 2009 | Sharp AR-407 Copier
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
I have Sharp AR-407 Grayscale Copier and i got the problems in it . it showing me the E7-11 code . i dont know how to solve this problem . can any one help me to solve it thnx
this is ccd white correction , clean the opitus really good and under the plat on the right side make sute there is no condisation or dirt on white plate
Jan 14, 2009 | Sharp AR-407 Copier
Code H5-01 indicated from the screen
H5-01 Exit sensor problem try to reset with simulation mode Press "Program" Press "Interrrupt: Press "Clear" Press "Interrupt" enter 1 & 4 then Press "Start"
Jul 12, 2008 | Sharp AR-407 Copier
Sharp Digital Imager AR-407 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
