Question about Canon PIXMA MP780 All-In-One InkJet Printer
Dark copies. Hi. Is there a way to clean the "reading glass" (panel)? Its so foggy underneath and makes very dark copies(blocking the exposure lamp) Thanks.
  • Tech4all
    Tech4all Oct 23, 2008
    Hi Check. The optic is encased inside the scanner unit..
    I 'd be able to detach it from the printer but don't know how remove the housing to get to the glass .
    I have it for 2/3 years. I guess dust & heat (Humit) starts to build up.
  • Tech4all
    Its all plastic casing...No screws..Kind of taps locking. I'm afraid to break it and mess up the scanner...
    I used to work for Canon USA for 17 years (Field Svc Technician) . The first thing we deal with copy quality is to clean the optics BEFORE messing around adjustments. I have seen how fast the optic system gets dirty...(Some within 6months) depend on models,and regardless the environment around it.
    Sure , Pixma780 has fl/lamp that creates less heat but still accumulates in time.
    I'm retired now....and not as techy as used to be,and don't have alot of money to buy a new one.
    Thanks for your help.
I can copy on my pixma mp780 but it won't print anything.
Says does not locate the port? Bought a new USB cable and that didn't help.
Posted on Feb 25, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
If it's underneath the glass, you need to remove the top and clean it. The oher issue here is Why is it getting foggY??? THAT should be a concern to you.
Either let it dry naturally, or remove the top to clean.
Posted on Oct 23, 2008
  • CheckitRight
    CheckitRight Oct 23, 2008
    That is not normal, it doesnt matter how long youve had it, it must be somewhere that retains high humidity.
    First remove the ADF, then remove the plastic casing for the top, there will probably be about 6-8 screws depends on the model, once its off ( I would leave the connections, and just leave the top hanging) and clean it, then re-install it.
  • CheckitRight
    Hey there fellow canon tech, I've only seen that on the copiers not on other machines and canon is known for being dust sensitive.
    Anyway, good luck.
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Nov 27, 2014 | Konica Minolta Konica 1015 1120 1212 Toner...
My copies are not very dark
Is the problem only with copies? Does the machine also print light?
If is it copy only, remove the glass and clean the lamp and mirrors in the scanner.
If it is both copy and print, then you should clean the laser shield glass and replace the developer.
Jul 28, 2010 | Sharp AR-M455N Copier
I have a FP7113 it only makes dark copies
dark copies you mean there is a dark background but image is still there?
it is usually happens when all mirrors and **** glass becomes dirty. you should clean it
well if you mean an image with pure black copy output, probably your exposure lamp is busted or the thermostat is open. :)
Mar 03, 2010 | Panasonic FP-D355DC Copier
Cannon 6 RE PC gives black copies
does the lamp under the platen glass turns on when copying? if not you might need a new exposure lamp...but if you get an image but its very dark, if you are mechanically inclined you can clean the mirrors and lens and the bottom of the platen glass because after many years of use dust will make the optics dirty and cause the copies to be very dark. hope this helps.
Dec 31, 2009 | Canon Office Equipment & Supplies
Copier is making copies super dark and with a white line in the botton of the page
Hello sir; Check the exposure lamp, is out or weak it make dark copy.
Aug 17, 2009 | Canon Office Equipment & Supplies
MINOLTA COPIER EP 1083 IMAGES TO DARK, NEW TONER, CHANGE PAPER
what is your exposure lamp brigthness condition? checkyour upper high voltage adjustment , check your exposure lamp & bright it & clean your copier lens.thanks.
Oct 05, 2008 | Minolta Office Equipment & Supplies
Adjustment program
Try cleaning the Auto Exposure sensor, or disabling the AE feature in standard settings. Some copiers have exposure calibration in standard settings too. Increasing the lamp intensity may cause further premature wear down the process line. (What machine have you got?)
Aug 27, 2007 | Gestetner - DSm660 Digital Imaging System...
Dark Copies
Jim, A couple of things: 1. OEM (Canon original) toner cartridge or remanufactured/compatible? The first place to start is always with the toner cartridge when image problems occur. Pull the cartridge out and draw back the drum cover. Check to see if the drum is a nice "clean" blue color or if the lines and spots are on it like you described. (These two areas should be handled by someone with experience in copy service) 2. The next thing would involved cleaning under the copy glass. Build up from dust, etc causes a "fogginess" that makes the machine try to adjust the intensity of the exposure lamp to conpensate for this. 3. Also could be a bad upper fuser roller if you started having any paper jams when to paper exits.
Jul 18, 2007 | Canon imageCLASS D320 Digital Copier
One side copy dark
I would check the scanner slit glass under the toner cartridge. Clean the optics, pull the PCU out and clean the LED erase lamps. After this I would say it was the PCU. I NEVER would mess with the exposure baffles or the focus. http://www.tonerovernight.com
Mar 31, 2007 | Ricoh Aficio 2015 Copier
Canon PIXMA MP780 All-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
