Question about Pioneer Computers & Internet
Dvd-rw dvr td 09a ata Drive not recognised by software
Not recognised by imgburn or proshow
  • 1 more comment
  • BERNARD CRAVEN Feb 13, 2012
    I have applied your answers to the problem but there is no change
    There is no red or yellow exclamation marks no upper or lower filters
    The drive will not play or burn
    Thanks for your time
    BARNIE
  • Brian Sullivan
    Brian Sullivan Feb 13, 2012
    It could be a problem withthe lens, you could use a liquid type cleaner by placing a couple of drips onto a cd /dvd then run the cd for 30 sec
    or
    try cleaning the lens it's already gone bad there is no harm in trying
    If you take a little risk can solve . follow the instruction: Don't panic its very simply.
    1.When running your pc , open the drawer.>
    2. switch off the acpower
    3. remove powercable & sata or pata cable
    4. remove all the screw from the back side
    5.press clip to open the font panel
    6. reverse the cd/dvd rw
    7. just remove the cover
    8. clean the optical lance
    9. use a little( not much )oil place on two steel shaft
    10.cover all the equipment
    11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected..
  • Brian Sullivan
    how old is the cd/dvd and how much use has it had
    you might be up for a new one
  • Pioneer Master
  • 27,725 Answers
If its not recognised in windows explorer
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Posted on Feb 11, 2012
  • 979 Answers
SOURCE: I have a big problem
Did you install the drivers/software for this drive?
Posted on Feb 29, 2008
SOURCE: dvd-rw dvr-k17rs ata with aspire 5610z
Posted on Aug 30, 2008
SOURCE: pioneer dvd-rw dvr-k17 problem
This worked: thanks to riozebratubo
delete the entires in regedit.exe
"UpperFilters"
"LowerFilters"
They're inside:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
-uninstall the driver
- restart
Vista is searching for existing drivers -> done
Posted on Oct 25, 2008
  • 3422 Answers
SOURCE: JVC DVD Burner fails to recognise DVD
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Also Make sure your box is not blowing really hot air and nothing is right behind it blocking it.. Turn it off for a few minutes and let it cool down and then give it a try playing the discs..
Posted on Apr 09, 2009
SOURCE: DVD-RW DRIVE (D:) IS NOT WORKING
if its old one..get a dvd cleaner(it will be a dvd embedded with small brushes and a solution) and clean up your player's lens..make sure you dont touch the lens with your hands and respond back..one thing i am unsure is the availability of such cleaner in your country
Posted on May 22, 2009
Download driver software for PIONEER DVD-RW DVR-K17LF ATA Device
manually download it from the pc makers website drivers section and point the driver setup to the folder.
Nov 09, 2008 | HP Pavilion dv6000z Notebook
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
it's look like you have problem with dvd isnot showing in windows explorer / dvd driver.
Try this step from microsoft http://support.microsoft.com/KB/314060
basicly just update (delete some key) the windows registry and restart. ussually this work ok.
Jul 31, 2008 | Toshiba Satellite P105-S9722 Notebook
My DVD burner is not recognising blank DVD
i had that problem and turned out ot be defective drive. if u cant boot a known good cd like memtest.org (extract them burn .iso image with imgburn.com)
Jun 16, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
I wish to download the Software drivers for Pioneer DVD RW
May 24, 2008 | Computers & Internet
Feb 29, 2008 | Pioneer Slim 4x ATAPI (DVRK12RA)...
Can't burn movies onto dvd
in the software that u use to burn dvd...may be nero or roxio turn the dvd option on or select the dvd burning option.......u cannot use the xp writing sotware to burn dvds
Jan 01, 2008 | Pioneer DVR-112DSV DVD+RW Burner
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Computers & Internet Logo
172 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
