Question about Canon imageRUNNER 7200 Copier
105 CANON IMAGERUNNER E000542-0001 - Canon imageRUNNER 7200 Copier
4 Suggested Answers
spinal
  • 287 Answers
SOURCE: Canon imageRunner 105
Hello PE. I will tell you what the code means and although we can reset the code, if the PROBLEM still exists I am afraid the code will of course return when the copier performs a diagnostic. By telling you the reason for the failure perhaps you can fix the problem and therefore MR. COPIER wont be pissed. :-) This code means that the paper supply referred to as tray "B" has a problem.The lift motor for that paper supply could not (or the copier believes it could not) successfully lift the paper to the correct paper heighth required to feed the paper. This explanation may help you correct the problem.Now to clear the code. On the operator control panel next to the nine key pad is a button that says "additional functions". That button will be part of a 3 step process. Press the the additional function button>>>> next press the numbers 2 and 8 together at the same time>>>> then back to additional functions button.This is a 1,2,3 process that should be executed in a smooth but timely fashion. This will bring up a new window on the screen. Ther will be several "blocks" on the screen and one will say COPIER. Press copier.Then a new screen appears with several tabs across the top. One of those tabs will say FUNCTION. Press function.The screen will be filled with an assortment of blocks and one will say CLEAR. Press clear, and a new set of blocks will appear.One of the new set will say ERR. Press err and then in the lower right hand corner you will say a block saying "OK". Press ok. Now unplug the machine and wait a few seconds and plug it back in.You WILL have successfully erased the error code and the machine will perform its power on diagnostic as if nothing was ever wrong. However if the problem still exists the copier will see it and the code will return. If it does, you can perform the process again but this time pull tray "B" out so the copier cannot run a diagnostic on it. This is merely a workaround and will allow you to use the copier and its remaining paper supplies. As to what specifically the problem with paper tray "B" is could be several things, all of which would require a tech to come out. I must assume that is what you are trying to avoid (as would I ....$$$$$) I hope this helps you and I wish you the best. SPINAL
Posted on Jan 19, 2008
  • 199 Answers
SOURCE: We have a Canon ImageRunner 8500 and we get this
In this case the finisher motor or motor sensor does not work properly. AS SM Main cause - The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Main cause The tray B lift motor (M12) is faulty. The tray B idle rotation sensor (PI18) is faulty. The tray B lower limit sensor (PI24) is faulty. The tray B paper sensor (PI17) is faulty. Try operating copier without finisher or contact an technician to repair finisher.
Posted on Jun 13, 2009
  • 59 Answers
SOURCE: CANON IR 7200 TROUBLE CODE E000542-0001
It's related to the finisher tray motion. It's usually caused by something getting in their way when moving down eg box of paper or dustbon.
Move anything that could be interfering with the tray switch off and on and test.
Posted on Jun 16, 2009
What is solution for E240 in canon ir 105??
E240 is a communication fault between the DCC and main controller.
Several cases were reported where the HDD was causing this. Symptoms included: Control panel locking up, machine suddenly powering off, and E240.
One case reported was resolved by replacing the main controller.
Perform HD-CHECK in service mode. If this doesn't resolve the problem replace the HDD.
Oct 30, 2015 | Canon imageRUNNER 105 Printer
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
Canon ir 105
sir what solution error 69
Jan 29, 2014 | Canon imageRUNNER 105 Copier
How do I print from my iPad to a Canon printer. I get a 105 error
hi what is the full name of your Canon printer?if anybody needs to see a list of airprint enabled printers which are ideal, they are here:
http://support.apple.com/kb/ht4356
no panic if not, you can still print from your ipad/iphone etc to a printer using a third party app. the one that seems particularly popular is print n share which i use. good luck
Jan 13, 2011 | Canon imageRUNNER 105 Printer
Where can i find pc drivers for canon ir 105
Go to www.canonusa.com and navigate to support and drivers. Then select your product and download what you need.
Apr 20, 2009 | Canon imageRUNNER 105 Copier
Printing speed slow
Try to run a clear server on your imagepass. (unless that is what you meant by clearing RAM)
You also may wish to restart the M3.
If you have a support contract, ask your dealer to upgrade or reinstall your fiery system software.
Mar 27, 2009 | Canon imageRUNNER 105 Copier
Canon imagerunner c3220
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Oct 31, 2008 | Canon imageRUNNER C3220 Color Copier
E000020-0010
Have you recently changed or added a new toner resently?? If so try to reinstall it or add a new toner. A E00020 is a toner desity problem. It may be a bad toner cartridge..
May 11, 2008 | Canon imageRUNNER 105 Copier
Canon imageRUNNER 7200 Copier Logo
165 people viewed this question
old marine
old marine
