Question about HP Pavilion a705w PC Desktop
Remove advertising strip from right side of screen
Especially during mail session. you can make center bigger by right arrow, but it does not hold permanently. advertising strip is distracting and takes up too much room.
    Master:
  • 388 Answers
Start ,control panel, add and remove programs find the advertisement program uninstall it.
Posted on Feb 11, 2012
I own an acer 10.1"
it isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
1063_66_99.jpg Remove the Camera Board from the LCD Module.
  1. Remove the four securing screws (two each side) from the LCD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cable.Carefully lift the adhesive tape securing the cable connector to the LCD Panel.
1063_66_105.jpg 5. Hold the adhesive tape clear of the LCD Panel and disconnect the LCD cable as shown.
  1. Remove the adhesive strips holding the MIC cable in place.
1063_66_107.jpg 3. Remove the MIC Board from the LCD Module.
  1. Remove the adhesive strips holding the Camera cable in place.
  2. Remove the Camera cable from the LCD Module.
  1. Remove the adhesive strips holding the Antenna cables in place.
1063_66_110.jpgCarefully pry up the Antenna pads, as shown, and remove the pads from the LCD Module. IMPORTANT: A strong adhesive is used to secure the Antenna pads in place. Take care not to bend the pads during removal.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
Apr 05, 2011 | Computers & Internet
How to make the screen on a laptop bigger
What do you mean by the "screen" ... "bigger" ?
If you're referring to the window size for an application, simply stretch/enlarge it using your mouse - place cursor on the edge of the window (see the double bar arrow icon) or at the bottom right corner of the window, hold down the right mouse button and drag it outwards (to enlarge it).
Aug 11, 2010 | Acer Computers & Internet
I would like to be able to read a full page email!
You are using yahoo free service...so the advertise will be coming always...but I can suggest you to change your screen resoulation (1280x800) to see full page of your email ...for further please comment here...thanks for using Fixya
Nov 07, 2009 | Yahoo Mail
The screen on my dell 2200 has flipped 90 degrees after my cat stepped on the keypad, how do i rectify this, back to normal.?
I have an Nvidia card on my laptop and I right click on a blank area of the screen and scroll down to Nvidia control center. Once that window comes up, there is a setting in the left pane that refers to display orientation. Ati has similar options for their cards.
Nov 03, 2009 | Dell Inspiron 2200 Notebook
Webcam not wrking
It sounds like the camera may need to be reseated on the motherboard. Could be a loose connection with the cable. You will need to get the keyboard and power strip off and access the cable from there. The cable runs from the right side of the display across the palmrest to the center lower part of the motherboard and plugs into a small flat socket. To get the power strip off, remove the battery, next...there are several screws you will see, all of those screw need to be removed, there may be 5-6. Now take the access cover off the memory/wireless compartment. There is a screw inside a tube marked with a keyboard symbol, this screw has to come out. Now turn the laptop over and pry the right side of the power strip up gently, just position it forward toward the screen just enough for the keyboard to flip up. Now shift the keyboard toward the screen so that the hold down tabs at the lower part clear the palrest. Now under the keyboard is the flat socket holding the keyboard cable, push the retaining tabs on both sides of the socket toward the screen, this releases the cable. Lift the keyboard free. Youcan leave the power strip where it is, it does not to be removed. Now look to the right side of the display at the right hinge. The flat cable is the camera cable, it is usually bundled next to the two wireless antennae leads. Follow the flat cable down to where it plugs into the motherboard. Pull the plug out and give the socket a blow of air to clean dust and debris. Now plug the cable back in and make sure it seats well. Put everything back together, go to HP and make sure you download the "Cyberlink" Youcan software drivers and the camera should work fine.
Sep 27, 2009 | HP Pavilion dv6000z Notebook
The transparent film strip has fallen of where does it attach to on the canon pixma mp460
The strip needs to be clean, there is an arrow on one end, needs to point up on the left side. Behind the carriage unit is a small slot that the strip passes through, a silver spring on the left to hook through the hole on the strip, and a solid metal tab on the right to hook the other hole to. It's not as easy as it sounds, especially with all the covers on...
Jun 21, 2009 | Office Equipment & Supplies
Picture not centered on my philips 47'' lcd tv
NOTE:(Edited and copied from another thread on Fixya.com, c7carl)
Picture is not centered on monitor leaving a 2 1/2 inch; black border on Philips LCD
By dmorrow54 on Nov 13, 2007
Again, nothing in manual for Philips LCD will correct the fact that the picture in HD-D mode will not center. The picture runs off the monitor on the left (facing the monitor) with a 2 1/2" black border on the right (facing the monitor). Using the format button on the remote of directional arrows will not correct the issue. The wide-screen/ full-screen function with format does nothing. Moving into TV mode, the format function works to display screen in several ways 4:3, 19:2, super-zoom, wide-screen, full-screen. Help, please. posted 3 years ago
Guest
  • Rank: Guide
  • Rating: 0%, 0 Votes
I have a Philips 30 inch LCD and solved the problem by using the circular arrow button on the TV remote. Pointing it at the TV and clicking "right" (3 o'clock on the button), the picture moved right. Same thing on for "left". Worked for me.
Add a comment
    • c7carl
    • 5 minutes ago
    WOW! It works!! The picture on my Magnavox (aka Philips) 37MF321D had shifted to the right. I figured I had a big repair bill coming up soon. But hey! Just used the TV remote as described by "Guest', and re-centered the picture to the left. Wallah! Thanks ""Guest" whomever you are! Reply
    Posting advertisements, profanity, or personal attacks is prohibited. Click here to review our Terms of Use.
    Comment:
Feb 05, 2009 | Philips 47PFL5603D 47 in. LCD HDTV
Decending view of unread messages
Above the message dates is a bar that says "date". Click it and then press the tiny arrow button until the arrow points downward. As for the ads, you can't get rid of them, unless you get the paid service. :-)
Dec 30, 2008 | Yahoo Mail
HP Pavilion a705w PC Desktop Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
