Question about Behringer EURORACK PRO RX1602 RX 1602
Need schematic and parts list
There are no lights, bells, or whistles. The unit is dead and has a slight electronic burn smell.
Repairing Korg D-3200 Digital Recording Studio
If you have electronic expeerience, take it to a repair shop. You can cause more damage okiong around if you don't know what you're doing.
Past that, contact Korg customer service for the schematic and parts list. The part should be available from Korg directly of from Mouser
http://www.korg.com/us/support/contact
Korg Parts Parts Is Parts Guitar Parts Amplifier Parts Korg Keyboard Parts
Mouser Electronics Electronic Components Distributor
Korg Full Compass
Jul 15, 2016 | Korg D3200 Digital Studio
Would like a parts schematic for a Bb400 gold tone bass banjo
This is a list of All the parts you need, I don't know about a schematic?
1 Maple Neck ? 1 11" wood rim ? 1 11" notched tension hoop ? 1 Flat head alloy tone ring (Optional bell brass available) ? 1 Resonator (not included in the open back kit) ? 1 11" Remo frosted banjo head ? 1 Arm Rest ? 2 Coordinator rods with hanger bolts (one longer than the other) ? 1 "L" shaped tailpiece bracket (may be attached to coordinator rods) ? 1 5th string nut ? 4 Guitar style tuners (planetary tuners optional) ? 1 Geared 5th string tuning machines ? 24 Shoe style lugs with bolts and washers ? 24 Hooks and nuts ? 1 Nut, pre notched ? 4 Resonator plates ? 4 Brass inserts (brass anchors that are threaded on the inside) ? 4 Resonator bolts (knurled on the outside with a Phillips screwdriver receiver on top) ? 1 5 string bridge ? 1 Gary Price style Tailpiece ? 1 Set of strings ? 22 Pre-cut (ready to install) frets ? 1 Truss rod cover (including three screws)
Mar 06, 2015 | Bass Music
Just bought a pair of used Beringers Truth b2031a monitors. one of which doesnt work anymore at all... opened the back of it (took those 6 screws out) and saw that the power connection has been cut of......
Here is the service manual schematics for your speakers:
http://elektrotanya.com/behringer_b2031.pdf/download.html
Scroll doen to "get manual" and click on it to download the manual... Do not click on the other downloads at the site, they are for viewers you don't need.
Take the schematics to a COMPETENT electronic service technician to get units repaired. You obviously bought units that had been hacked before...
Jun 21, 2011 | Behringer Truth B2031a 225-watt Powered...
I have Mackie SRM450v2 speakers, one has no power, I think the fuse has blown, it it possible for me to change this myself? The manual says it's not user serviceable.
Chances are if the fuse has blown, there are failed electronic components that caused the failure.
Here is a service manual that will be CLOSE to your unit, though not exact:
http://elektrotanya.com/mackie_srm450_active_speaker.rar/download.html
Scroll down to the "Get Manual" on the site and click on the link. The file is compressed. The first part is the schematic, the second the assembly and parts list. Likely the main low freq power amp has shorted transistors.
Apr 24, 2011 | Mackie Srm450v2 Srm V2 Active Speaker...
My Marshall mg100hdfx is a little over 2 years old and i never used it that much. I turned it on, made a popping noise and shut down. No smoke but i could smell a slight electrical burn smell. I never...
DO NOT try to use it until it is repaired or you may do further damage. Probably a capacitor shorted or a diode in the power supply. This is NOT DIY unless you are competent at electronic repair. When it is appeared to be restored, put a 150 watt lamp in series with the power cord to limit current till you know it is repaired... saves fuses and destroying further components if there are other parts that are bad.
Nov 03, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Effects Panel
If other lights are on, I have seen a case where the display does not light for a time, especially if it is cold. The gas in the display takes some time to light up like some neon bulbs... the effects should still work, you just can't see the display. Usually the display will eventually come on after a few minutes after being off for long periods. Sometimes one can encourage the display by external radiation such as a cell phone in close proximity.
See if the FX input indicator is functioning.
If the electronics of the DSP/FX is dead, troubleshooting it is not a DIY unless you have special test equipment. The unit uses two 57002 DSP's controlled by an 80C32 micorprocessor. Beyond checking that the 80C32 is operating and busses have activity, you probably won't be able to do any fruitfull troubleshooting
If NO lights come on in this unit, then the power supply has fried and you don't want that as it is likely caused by the rear power amp arcing out.. Lots of work to repair. Since rest is working this is not the case with yours. ALWAYS be careful to insure speaker leads are solid with this amp as an intermitent lead can blow this amp easily.
Behringer does not release their schematics to non-agents...
Jul 17, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Casio Headphone / line out connector broken - need electronic part number of headphone output connector (7 pin), or a schematic or description of switching options to find suitable replacement
The quickest thing to do is to match the connector with catalog illustrations at either Digikey.com or Mouser.com.
Search first for 1/4 inch, then filter selection with STEREO and PCB or circuit board mounted.
There is likely switches involved to turn off the speakers.
Finding a Casio parts list for the unit could be a major undertaking AND the part number would likely be a house number that you can only use directely from Casio.
Here is a link to some of the candidate ones:
http://search.digikey.com/scripts/DkSearch/dksus.dll
For those without an image, click on the part number and go to the PDF spec sheet for image.
Jun 16, 2010 | Casio 76 Key Smartmedia Keyboard
I have a Torque T652MK 65w Keyboard amplifier whick when connected up to an instrument the volume is very faint. After increasing the volume slightly (Nearly full) it automatically kicks in but only for a...
You found the problem.You will have to have the control replaced. If you feel comfortable doing it yourself, you will need an exact replacement part. If you don't have the schematic you can take the old one out and usually the value is stamped on the body or a code to help match it. You can also measure it across the outside lugs for resistance. You will need the same taper. This is explained at www.tubesandmore.com(Antique Electronics Supply) under Tech corner in Potentiometer Taper Charts. I'm glad you found the problem.
Aug 04, 2009 | Music
Blown fuse and replaced it and burned the amp
BIG problem! You should NOT have replaced the fuse as additional damage has been done. I repaired a PMP5000 and I can tell you likely what you will find: The smoke and smell came from two power resistors that are part of the soft start circuit that now are toast. You will likely find several components in the main portion of the power supply that are toast. These will include transistors, resistors, diodes, and probably the small 8 pin switching regulator chip. There is a small power supply that comes on first which enables a relay that shorts out those soft start resistors AFTER the power amplifier BALANCES and normalizes.
The unit I repaired had severe damage due to arc-over at one power amp section. Three power transistors were destroyed there and board traces and charring had to be handled in that section.
The repaired unit had to be brought up with a light bulb in series with the line power cord to prevent further damage until all bad parts were discovered and repaired. You will need to take the unit to a shop that is expperienced with the product. The repair cost MAY be pretty high.
Mar 08, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer EURORACK PRO RX1602 RX 1602 Logo
43 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
