Question about LG 32LD550 32 in. LCD HDTV
LG LCD Power Cycling issue
Hello, thanks in advance for any help, I have an LG 32DL550-UB. It is just over a year old and as luck would have it, has started giving me problems now that it's out of warranty. The TV keeps power cycling - turning off and on by itself - whenever ANY input is plugged into it and running. At first it did not happen very often, maybe once every couple of days, but now it has gotten to the point where it will not stay on at all. The TV will stay on if there is no input. For example I have a PS3 connected, and when it is off I can turn the TV on and it will not look like it has any other problems. As soon as I turn the PS3 on, it will power cycle continuously. I opened it up and there are no visible problems with the main board or the power supply. I called LG and tried a factory reset as well as a hard reset. I tried keeping it unplugged for a week, all to no avail. From doing some internet research I've read might need a new power supply, and if anyone can provide some insight it would be greatly appreciated! Thanks
I was having the same issue and found a solution for my particular problem, so I came back here to share it with you in case it works for you, too.
My LG 32LD550 started turning off at random, then more and more frequently to the point where it just constantly turned off and on, off and on. At first it seemed to happen only when there was an HD signal (HDMI, HD TV broadcast, etc.), then it started doing it no matter what. But I noticed it also happened whenever I used the side buttons on the TV. If you're having that issue, here's what I suggest:
Remove the back panel (13 screws--11 around the perimeter, one in the center, and one on the inputs panel).
Locate the small white plug connected to the side buttons panel, and unplug it.
Sure, you won't be able to use the buttons on the TV (so don't lose your remote), but if it works, you just saved yourself a couple hundred bucks. It's worth a shot!
Here's the video I found on YouTube that tipped me off:
http://www.youtube.com/watch?v=H0cG3lzjuw8
For me, the capacitors were fine. I just had a faulty control panel. Good luck!
Posted on Mar 12, 2013
  • 149 Answers
SOURCE: LG TV not turning on
Yes you can get this fixed and it is still worth it. It may cost $200 but it should last a long time.
Posted on Nov 13, 2008
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
toolkits
  • 1099 Answers
SOURCE: Plasma Television won't turn on
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
if otherwise the power supply board is faulty you can try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helps
Posted on Jul 02, 2010
  • 679 Answers
SOURCE: I have the exact same issue as the unsolved
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Posted on Feb 12, 2011
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 26, 2017 | LG Televison & Video
LG 42LC2D-UB TIVO Remote Stopped Working
Hi Did you check the batteries,and if they're put in properly.
Make sure you have fresh batteries and not 2 different kinds. then do your codes again. Good luck.
Feb 11, 2014 | LG 42LC2D 42 in. LCD HDTV
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
Feb 12, 2011 | LG 42LC7D-UB Television
Hi, I have a LG Flatron W2234S LCD screen and yesterday it started cycling through the light view modes and now does it intermittently What could be the cause and how o i fix it?
I had the same problem. Contacted LG as I was sure this model had a 3 year guarantee. It did, and it still had until the end of this year to run. They originally queried this, but on production of original receipt they happily replaced my unit.When I first checked the net, this model would appear to be less than 3 years old, hence it was definitely covered.
Give this a try, and good luck.
Ian Dickins
Jan 21, 2011 | LG Computers & Internet
The red power standby light is on. Turn on the TV , it turns green for about 15-20 seconds then turns red again. No picture, sound, or able to bring up menu. Have tried depressing the reset button on...
Hello repairdud304,
This is a common problem with Broksonic LCD televisions. (If you want to look them up you can search by their manufacturer Orion.) The problem lays within the power supply and a uneven voltage processor. This happens for no reason sometimes, but what acutaly happens is that a chip controls the amount of voltage coming into the tube. This chip has malfunctioned and works for about 15-20 seconds before resetting. This needs to be replaced. It can be costly. I'll leave you with some links that may help you in your voyage into Television Repair Land. Good Luck!!
Broksonic Manual(s) - Includes Troubleshooting Section
LCD TV Repair Specialists - Near you!
LCD TV Parts - Google Suggested!
I hope this solution helps you!
A Pleasure,
Guide - Vexed Demon
P.S. If you feel this answer to your question was great. Please take the time out to review me and give me a great rating! I am trying to level up and become a premium member to help others like yourself! The only way I can do this is by your ratings! Thank you for your time in advance.
Jan 13, 2011 | Broksonic CCVG-3276 32 in. LCD TV
I need to buy Powerboard for 26" LG LCD Television 26LX1D
There u go .!!
http://cgi.ebay.com/LG-Electronics%2FZenith-6871TPT303B-PCB---POWER-BOARD_W0QQitemZ390119483627QQcmdZViewItemQQimsxZ20091117?IMSfp=TL091117189007r1099
This product works with the following models:
LG Electronics/Zenith 26LX1D
LG Electronics/Zenith 26LX1D-U
LG Electronics/Zenith 32LP1D-UA
LG Electronics/Zenith 32LX1D
LG Electronics/Zenith 32LX1DUA
LG Electronics/Zenith 32LX3DCS-UA
LG Electronics/Zenith 32LX3DC-UA
LG Electronics/Zenith 32LX4DCS-UB
Nov 24, 2009 | LG 26LX1D 26 in. LCD HDTV
Replace main board on LG 42LC7D-UB
not sure what you're referring to as a "main board", but heres the LCD Control Board for the TV
http://cgi.ebay.com/LG-42LC7D-UB-LCD-CONTROL-BOARD-6870C-0119A_W0QQitemZ150277759127QQcmdZViewItem
Mar 13, 2009 | LG 42LC7D-UB Television
Power won't stay on
hello. you are not alone, this is a common problem with alot of new lcd and plasma tv's since they operate with high internal voltages the circuts have built in protection. any slight power fualt or short in the circut will cuase a sos or shutdown. may be a number of different reasons or even a shorted fuse.
it needs to be checked you have a power issue.
some models if there is a blinking led the number of blinks indicates the fualty area.
your tv needs service.
hope this helps
Dec 17, 2008 | LG Televison & Video
Wont turn on
same on my lg tv just got it fixed, it was the izuse power board at fault .
Nov 04, 2007 | Astar LTV-3201 32 in. LCD Television
LG 32LD550 32 in. LCD HDTV Logo
908 people viewed this question
Computer Repairing
Computer Repairing
