Question about Acer Computers & Internet
No signal to monitor and will not respond to manual shutdown.
This computer will not connect to a monitor when booting up. It never reaches a bios menu. Everything seems to be working fine. I have power to all fans as well as the Hard disc and CD drive. I can't see anything on the monitor to know for sure that it is booting completely. I have tested the monitor on another computer and it works perfect. Here are the specs Acer Brand Processor: AMD Athlon Duel Core 64 Bit OS:Windows Vista Home Edition Ram:4 GB 500 GB Hard drive Integrated ATI Radeon Graphics I have researched for a long time on this now and it seems that it could be hardware failure due to overheating. I don't have a way to check this though. I can not test the graphics card because I don't own one at the moment. I am just trying to get a little more help on the situation so I can fix it myself. Thanks in advance.
  • Jeremy Farmer Feb 10, 2012
    I also have to unplug it from the wall as it will not respond to a manual shutdown by holding down the power button.
  • Dilum Senarath
    Dilum Senarath Nov 09, 2016
    did you here startup sound or music? working led on the key board caps lock , numlock.
    therefore pls run computer by safe mode by press f8 while booting up, and remove video driver and try again.(may show video in safe mode )
  • 388 Answers
Sounds like the wire to the power button is disconnected also remove the battery unplug form the mains leave for an hour restart the machine without the battery to reset the CMOS
Posted on Feb 11, 2012
  • 51 Answers
SOURCE: ATI RADEON 9550 X 1050 256MB --Someitmes Screen goes blank
try reinstall the video card driver !
check the back of the game box if 1.6 ghz is enough power its kind of odd if it does it just on that game cause your ram memory is enough !
get the new drive off the ati website !
it could be a multitude of problems ! the video card could also be overheating ! if the screens says no video signal after it stops you card is the problem!
also you motherboard could also only support 4x video card therse a lot to lean on here !
Posted on Jan 14, 2008
SOURCE: Samsung LCD monitor SyncMaster 1731
Problem with screen(LCD monitor), no problem with your system. replace it
Posted on Mar 18, 2008
  • 77 Answers
SOURCE: more compatibility problems ?
what you will need to do is accertain which cpu format you have in your machine and find out if you have pcie 1 or 2
regards rich
Posted on Feb 24, 2009
  • 77 Answers
SOURCE: upgrade compatibility continued
as this pc is skt 775 and has dual core support then it is quite likely that the e5200 will work but may need a bios update to support this cpu...
just goto dells site and choose the pc u have and select drivers then download the lastest bios, transfer it to the dell pc run it as its a self extractor system will reboot perform the update then bobs ya uncle.......pop in new cpu and hey presto cheapo ugrado
#and as for the graphics card you will need to accertain which pcie version u have as most dell pc's only have pcie v1 so wont be able to handle the newer gpu's on the market.......
hope this helps
Posted on Feb 25, 2009
  • 54 Answers
SOURCE: ATI Radeon 1650x Problem in Installation
Some games require high settings, they run on phsx, sli, 256mb-512mb. Ram is also a factor, When installing a good graphics cards some things change and it takes some power to run them. Although I made one run on 480 watts its not recommended, Later as you ad more features (upgrade) 550watts is some of the minimum system requirements to run at least one graphics card. If its still doing the same thing after the power supply, Another is make sure the upnp (universal plug and play) and pnp (plug and play) are enabled in the services menu.
Posted on Sep 22, 2009
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
When i plug up the L1975NW lcd monitor what should show up ?
"no input" means that there is no signal from computer or the monitor cable is unplugged. When you first turn on monitor it usually does a self test and then looks for signal. Not connected to PC will give a no signal. If it is connected but PC is off (not unplugged) then it should go into standby as you vid card will be sending a standby signal to any monitor connected. Sometimes the Plug and Play monitors need to register before it will recognize a standby signal from PC, so plug it up and boot up PC. Then shutdown normally, your monitor should go into standby when the PC shuts down.
Nov 11, 2013 | Westinghouse L1975NW Monitor
PC wont boot beyond point where fan speeds up considerably
check in BIOS settings and see is it the temperature rising or maintain?Sometimes when temperature reach the maximum, the mobo will force to shutdown to prevent damage.
Jul 03, 2012 | HP Pavilion a6417c Desktop PC / Athlon 64...
Will this dvd device, boot a dvd before windows starts?
Follow below steps
1. Shutdown the computer and connect the DVD RAM burner.
2. Switch on the computer.
3. Before the boot menu, press Esc. You will reach the BIOS.
4. Navigate through the BIOS GUI to find the newly connected DVD Burner.
5. Insert the bootable DVD into that drive.
6. Change the boot order options in BIOS, so that the computer will first searches for DVD Drive before reading Hard drive
7. Save and exit the BIOS to restart the computer.
Now the computer boots from the bootable DVD inserted in the drive
Aug 06, 2010 | Samsung SH-S223F DVD-RAM Burner
No signal
Check cable connections. Check using a different monitor.
The only other possibility is that you're trying to drive it with a signal that is beyond the capability of the monitor. But the computer boot-up (BIOS) screen won't exceed the monitor's capability.
May 15, 2010 | Sharp LL 172A-B 17" LCD Monitor
When I turn on my computer the monitor remains dark unit after about 10 mins then I get the windows desk top. If I shut down the computer (normal shutdown)then restart I get the normal startup...
Try connect your monitor to some other box and try if it works the same way or as a normal pc boot. If it works well with other box, the issue is with the BIOS. Get the BIOS flashed with the latest version of flash program for the Bios chipset which your board is using. If the monitor shows the same symptom on a different box too.. you may need to get your monitor repaired. Good Luck
Feb 14, 2010 | ASUS P5PE-VM Motherboard
After i'm on the computer for 45 min. to 1 hour, my monitor goes blank and I get a "No Signal Anolog" message. If I re-boot right away, the time decrease's to shutdown. Need solution
What you got here is the monitor ether going to sleep when not instructed to do so or a fualty videocard,bent pins, or poor solder connection inside. Without looking at it its hard to tell please do not shoot the messanger here thanks
Aug 10, 2009 | ViewSonic VA1912wb Monitor
Upgrading graphics card
Connect the monitor to the onboard video connector first. then
you need to disable the on-board graphics in the BIOS save the setting and shutdown. Then connect the monitor to the GeForce video connector and boot up then you will get a video signal on the GeForce video card.
Apr 29, 2009 | Acer Aspire M3201 Phenom X3 8650 PC...
Video signal
If it worked fine before the AGP card was removed then the problem is probably related to your BIOS settings. The BIOS setting that controls the integrated video may be set to OFF.
  1. Insert an AGP video card
  2. connect the monitor to the card
  3. boot to BIOS
  4. check settings
  5. turn ON integrated video
  6. save and exit BIOS
  7. shutdown
  8. Remove AGP card
  9. connect monitor to motherboard video port.
  10. Reboot.
What happened?
Jan 26, 2008 | EliteGroup 661FX-M Motherboard
Computers & Internet Logo
77 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
