Question about Frigidaire ATF6000ES Front Load Washer
Elecrtonic controls keep coming on when washing machine is not working
We had the same problem and after calling a tech out it turned out to be the switch for the door had to be replaced.
Posted on Feb 16, 2012
Fisher and paykel washing machine keeps beeping
Unplug control board and replace it.
May 28, 2013 | Washing Machines
I have a ghost, My Frigidaire washing machine will come on by itself with the controler off. If it is running a cycle it just keeps going even if you push the button off. unplugging it is the only way to...
Possible that the program controller is defective. You can remove and clean all the connections to the controller, check all the harness to the panel, if not the controller is a suspect.
Jan 17, 2013 | Frigidaire Washing Machines
My washing machine comes up with error code 4e i have changed the solenoid valve and cleared any possible blockage water is flowing in to the machine but still getting the same error code if i chose the...
Your machine has a fault with the water level contoller switch - pressure switch that activates when water reaches the level set . So check the water level controller and test. If not the fault can be with the program controller unit.
Please check this link for parts identification.
http://www.espares.co.uk/advice/washing-machines/a/7/40/identifying-washing-machine-parts.html
Sep 17, 2011 | Samsung Washing Machines
My LG WT-R807 8KG top loader washing machine will not rinse or spin I have a huge load in there at the moment. Have removed most of washing from it still won't drain. Have tried turning machine off and...
Did you try it in other cycles (delicate, permanent press, etc.)? The more symptoms - what works and doesn't allows better advice. Because right now it could be the control board, the timer, the drain pump and more.
Also you need to give us the model number off the id tag in your unit since that once keeps coming back as invalid.
Jul 14, 2011 | LG Washing Machines
Whirlpool AWO/D4305 Washing Machine. The "Water
Providing that the tap is turned fully on AND the hoses are not kinked or squashed at the back, this is symptomatic of a malfunctioning water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs a service call ;-0(
Good luck,
John C
Mar 27, 2011 | Washing Machines
Code F1 keeps coming on and stops cycle.
F1 is a primary control failure. First unplug the machine,open the control panel. Locate the p-11 connector. Unplug it and re-plug it securely. If the code continues or the machine fails to operate,replace the machine controller.
Oct 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing maching says door open
As you have replaced the interlock switch check that it is working my using a multimeter on it.
If that is Ok then you probably have a problem with the wiring from the switch to the controller board or with the controller board itself.
Sep 12, 2009 | Whirlpool Washing Machines
Beep coming from washing machine
You might have the end of cycle setting turned on. It will beep to let you know that the washer is done. Can turn off, under options on the control panel.
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Time saver on my Hoover Hd Vision washing machine keeps coming on mid wash! Don't know how to cancel it.
my machine had the same fault and seems to be quite common. What I didwas remove the pcb behind the control panel buttons, its held on byseveral plastic clips and simply ensure the ribbin cable was making agood conection from this board to the programmer. My fault was either aloose connection or the pcb was not in the correct position either way,it now works perfect and only took 5 mins work @ no cost.
Aug 30, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
