Question about Dell Dimension 2400 PC Desktop
DNS error How to fix a dns error on windows xp
  • 1,031 Answers
To fix to the "DNS error" in windows
XP. go to>Control Panel -> Admin Tools -> Services
Find DNS Client and Stop it, wait a few seconds. Then start DNS CLient
again. Can continue without rebooting or reconnecting.
.hope this helps pls appreciate by rating it
Posted on Oct 23, 2008
Dns probe finished no internet
Issue is with your internet connection or network adapter. Suggest you follow the steps listed below to fix this BEST FIX DNS PROBE FINISHED NO INTERNET
Mar 11, 2014 | SVP NEW
Dns error laptop
Instructions
    • 1 Refresh the page that failed to load. If the page reloads, you just had a momentary lapse in service that happens with most providers. Between each following step, try refreshing the page to see if the problem is resolved.
    • 2 Check the page address you typed into the address bar to make sure it is spelled right. An error in the URL address could cause this error message.
    • Sponsored Links
    • 3 Go to your connection settings and make sure the settings match those of your Internet serviceicon1.png provider or local area network. Do this by clicking on Tools on the toolbar, then Internet Options. Under the Connections tab, click Settings.
    • 4 Click the "Detect Network Settings" link on the Interneticon1.png Explorer page accompanying the error message to let Windows try and find an optimum connection.
    • 5 Download DNS error fix softwareicon1.png off the Internet if no other option works (see Resources). The software is free on some websites and should be able to identify the problem and correct it.
Nov 21, 2013 | Lenovo Computers & Internet
Dns server error address
Dipesh,
Click the link below for information on resolving this error.
How to resolve DNS error in Windows XP and Vista
http://dell.to/14Mdox3
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Sep 13, 2013 | Dell Inspiron 1420 Notebook
Eror 105 wifi
Error 105 is one of the most commonly faced errors by a lot of users everyday who are using Google chrome
Error 105 is a DNS resolution error. - Which means when you enter the URL of the website and hit enter in Google chrome, it tries to resolve the IP address of the website using a protocol called DNS (Domain Name System). If chrome is unable to reach the DNS server, the name resolution fails and you get the error 105.
Solution:
Once you have verified from your internet service provider that there is no problem on their end, follow the step by step instructions below.
We are simply going to add a manual DNS address in Windows so that chrome is able to resolve DNS queries.
1) Press [Windows Key + R] to open the "RUN Dialog"
Alternatively, you can also click on the start menu, type run in the search bar, and you will have the RUN Program.
Once you have the RUN box, type in ncpa.cpl and click OK - This would work for all Windows operating systems including Windows Xp, Vista and 7.
2) Next, Choose the correct network adapter (from the icons)
If you are connecting to the internet using an Ethernet cable, then most likely you are using a desktop computer. Right-Click "Local Area Connection" and click "Properties"
If you are connecting to the internet using a Wi-Fi Connection, then Right-Click on "Wireless Network Connection" and click properties
3) After you open the properties window, select "Internet Protocol Version 4 (TCP/IPv4)" and click "Properties"
4) Usually you would be having both the options set to "Automatic"
In the section below, select the "Use the following DNS Server Addresses" and enter the following values Preferred DNS Server - 8.8.4.4
Alternate DNS Server - 8.8.8.8
and click "OK", then click "CLOSE"
You must now test your new configuration by browsing a website - you can also try and browse the website you were trying to get to when you got the error 105.
Jul 06, 2012 | Microsoft Windows XP Media Center Edition...
I am getting a dns error on ps3 80710102 how do I fix this
This DNS error is a simple fix. Simply go to your Internet Connection Settings and change the DNS part of it to Manual. Then for the DNS enter one of these two DNS's 208.67.222.222 and/or 208.67.220.220
this should fix your DNS error!
Hopefully this information helps to solve your problem!
May 16, 2011 | Video Game Consoles & Games
I am keep getting error of '' can not find server or DNS error''.. But i am fully connected to wireless interenet through NETGEAR.
This error means there is no communication with DNS server which can be because of corrupt dns cache. This fairly common in xp but is easy to fix. Now since you are saying you are connected wireless this might be nic card message. Try to disable LAN driver from network connections in xp or network and sharing center in vista and windows 7 and see does it still give you the error. If there is no error you can leave it disabled but if still there you should only be able to connect to internet via IP address but not name like google.com. Try to open command prompt and run command ipconfig /flushdns. In vista you have to run CMD.exe as adminisrator by doing right click other wise it wont do it. Hope this helps.
Feb 28, 2010 | Computers & Internet
SONY PS3 how fix the error 80028E01
error code just means that Sony is having server issues. wait 30 min and try again. sometimes they get bogged down on release dates of games.
or
One solution that worked for me:
When trying to get online you may get an error 80028e01 .
What I did was try various DNS server addresses until one WORKED!
Look here:
Free fast Public DNS Servers List
http://theos.in/windows-xp/free-fast-public-dns-server-list/
I used:
Service provider:dnsadvantage
Dnsadvantage free dns server list:
  • 156.154.70.1
  • 156.154.71.1
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
D:/windows/system32/shdoclc.dll/dnserror.htm
Hi hemgri,
the answer to this problem is unfortunately not that easy, because multiple reasons can cause this error.
It could be a simple DNS or DHCP service error, that can hopefully be fixed by restarting the services
  1. Go to Start>Run and type "services.msc" and click ok
  2. In the list look for "DHCP Client". Right-click and choose Stop
  3. Then right-click "DHCP Client" again and choose Start.
  4. Then look for "DNS Client". Right-click and choose Stop.
  5. Once again right click "DNS Client" and choose Start.
  6. Double-click your Internet Explorer button and all should be working now.
It is also possible that your DNS server is not working properly. What ISP do you have and what are your DNS servers? Try assigning a static DNS server.
  1. Go to Control Panel>Network Connections.
  2. Right-click on Local Area Connections and go to properties
  3. Double-click on Internet Protocol (TCP/IP)
  4. Chose "Use the Following DNS server"
  5. Type in 4.2.2.2 on the first line and 4.2.2.3 on the second line.(These are Verizon's DNS server.) Click OK.
We are just going to use theseDNS to see if there is something wrong with your ISP's DNS. Try browsing and see if it works. If it does, you can also use one of the open DNS servers instead of the one's from your ISP, i.e. OpenDNS's free DNS servers: 208.67.222.222 and 208.67.220.220.
If this still doesn't work, then there is a possibility that your computer is infected with a virus. To do something about that would be too much for this forum, because it involves posting of 'HijackThis" logs. Have a look here, someone had the same problem. Try to find help there - the guys are really good and know what they're doing.
Please leave a comment, so I (and maybe others) can learn more about this.
Jan 08, 2009 | Microsoft Windows XP Professional
First timer installing a Server network
Well i'm just going to start where i would start. First off, how do your machines on the network get their IP? DHCP?
Is the first listed DNS server the AD server? 192.168.1.1?
Also make sure your using case sensitive domain information when your trying to connect. It is rare but i have had that be my trouble.
I have remote software available and would love to help you fix this hands on if possible. I live for network problems ;)
Sep 29, 2007 | Microsoft Windows Server Standard 2003 for...
Win server 2003 enterprise
You need to ensure your DNS server is the first in the workstation's DNS list.
Does this help?
Sep 27, 2007 | Microsoft Windows Server Standard 2003 for...
Dell Dimension 2400 PC Desktop Logo
308 people viewed this question
Alun Cox
