Question about Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
Am replacing (or attempting to) an old non-digital Honeywell dial thermostat with the Honeywell rth230b thermostat. I have Y- G- W- R- B wire coming out of the wall. On the old thermostat the blue wire was not used, it was wrapped up and tucked into the wall space. The rest of the wires when to their corresponding colors:
Y = Y
W = W
G = G
The red wire was stripped bare in two places and wrapped around both red (h & c) terminals.
I put the red wire in the Rh and used the jumper provided to the Rc and connected the other wires to their corresponding colors.
I put fully charged batteries in the unit and actually tried 2 sets. The only thing that I can get to work is the fan while in manual mode. The thermo shows the little flame and snowflake when switched in too heating and cooling modes but nothing happens. It is easily ebough to program it. Trying to manually change themp I get no reaction from the funace or AC. It is an older OIL burner furnace and it worked fine before the change.
Any Ideas?
  • Mike_Schwin Oct 30, 2008
    Thanks for your help. It was a combination of things.
    1. Being the delay on the start up. It only mentions the delay in the AC mode not the heat mode.
    2. Apparently when installing the new thermostat on an old plaster wall it does not sit flat. After waiting for the delay and nothing happened I was going to replace the batteries again I was pushing on the t-stat and the fan kicked on. I tried holding it tight to the wall and the heat kicked on. 1 small shim later and I had some glorious heat. I am going to find a better solution light building up a mounting plate, but for now I have heat!
  • 96 Answers
On most Honeywell Digital T-stats there is a 5 min delay built in
Posted on Oct 26, 2008
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see . The direct link to the manual in English is .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
Honeywell com yourhome
Yes, it should work. Old thermo has 4 wires, follow instruction with new thermo.
Jul 22, 2014 | Honeywell Universal Digital...
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Help! replacing WeatherKing thermostat with Honeywell RTH230B
Sep 18, 2009 | Heating & Cooling
I have Honeywell thermostat (RTH230B). The heat set works well, but cool set does not work. My air condition works well with my old thermostat. What's the problem. Thanks
Do you have an Rh and Rc terminal on t'stat and do you have 4 wires coming into it?
If you do then you need to put a jumper wire from Rh toRc.
Sep 10, 2009 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
846 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
