Question about Whirlpool GHW9100L Front Load Washer
Water level adjustment
Our front loading kenmore washer we've had for over 5yrs, simply dosn't use enough water for washing or rinsing. Yes we have checked the inlet hoses and screens and they're fine. Its been this way since we bought it. We want to increase the amount of water used, how and where do we do this?
Thanks!
Lucy
  • melbrookes Dec 10, 2008
    Why doesn't anyone answer this simple question? We want more water in our washing machines. got a probelm with that? And it seems really stupid to invent a water saving "device" when you have to flush it twice to do the same job as an older unit. Stupid. And this washing machine thing is more of the same. Fixit Fixya. Gimme an answer!
  • Anonymous Mar 01, 2009
    http://whirlpool-dueling-with-duet.blogs...
    No one should have to go through this just to get a little more water in their machine but I did because I couldn't afford to buy a second new machine and wind up with the same problem.
    People reading the above blog please understand my solution to the problem was to add what I fondly refere to as the Washday Robot an extream solution to the problem. I posted the information to the web hoping that others would realize that too little water was most often the problem with this style of machine and would hopefully cause others to try different solutions to solve the problem. Mike was one of those people that tried by making adjustments to the machine that would cause it to use more water. This adjustment that he made to the pressure switch worked for him and according to many emails that I have received has worked for others. My only observation is that the adjustment he used is an all or nothing adjustment, which probably means that its not adjusting the pressure required to trip the switch. If this adjustment modified the pressure required to trip the switch one would think that any adjustment to the screw described in Mike's email would cause some increase in water level. This doesn't seem to be how the adjustment works though, it seems to take two full turns to the adjustment screw at which point water level increases to a more useable level. I have never tried this on my machine and I have never take my switch apart to try and see how it works. I posted Mike's email hoping that it was a fix to the problem and that others would have the same success that Mike had with his machine. What has driven me to try and get the word out about my experence with our machine and the fact that it doesn't use enough water was when I would read Post by little ladies with a plea for help, they had purchased these machines in good faith and often times couldn't afford to try again because of the cost. They shouldn't have to, the manufacture should have to correct this problen to the satification of the customer. I think as a customer the only way we will ever make this happen is to find the machine that will do the job and support that manufacture, and the only way to do that is to get the word out and get feedback on what others have experienced.
    I will end by telling you that the controller that I added to our machine and how I interfaced it to the machine will allow me to control more that I need to to solve this problem. When I started I wasn't sure what it would take to make the machine wash and rinse properly but in the process found that just adding water to each cycle was all that was required. We do add an extra rinse to each wash cycle and the we use the rinse and spin cycle with an extra rinse every time we wash anything. This may be overdoing it a bit but I don't think so when I look in the washer on its final rinse cycle of the wash cycle and still see soap in the machine. If water could be introduced during the spin cycle and distributed across the full depth of the tub allowing this water to be pulled through the cloths as they spin would probably do the best job and use the least amount of water. I don't think you can say a machine is efficient if it doesn't use enought water to wash and rinse the cloths even if the water bills go down. New cloths usually cost more that a little water, if this wasn't the case we would all be dressed fit to kill!!!
    Sincerely,
    Joe T.
On kenmore washer remove or find water level sensor and adjust the level control with phillip headed screw turn clockwise raises water by about two inches in a top load washer
Posted on Apr 01, 2013
  • joe molnar Apr 01, 2013
    turn screw a 1/2 turn
  • 1,543 Answers
You don't. Front load washers use only a very small amount of water. They fill a small amount, tumble a bit, resulting in water being absorbed into the clothes, which drops the water level in the tub. The washer senses this and adds more water, which repeats until water level stabilizes. The only way to get more water on wash cycles is to use delicate cycles, which use more water, resulting in a more gentle wash action. Remember that due to the low water consumption of front load washers, you should only use one tablespoon of HE detergent per cycle. (even less if you use 2x or 3x concentrate.) This is a FixYa solution. Your washer is working as designed.
Posted on Oct 23, 2008
Get water level higher
Water should just reach bottom of wm door .
Aug 10, 2014 | Kenmore Elite 45986 Front Load Washer
Not enough water in kenmore elite 24956301 top load washer
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 21, 2013 | Kenmore 24952 Top Load Washer
Does kenmore recommend liquid or powdered detergent for front load machine
liquid is best as powder is mostly made of a "clay base" in its detergents??? yes i did say clay!
Nov 28, 2010 | Kenmore Elite 45986 Front Load Washer
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Apr 21, 2010 | Electrolux EIFLW55HIW Front Load Washer...
Very little water on wash cycle
water level is determined by the pressure system, and no adjustment can be made.Ensure your programe is not selected to half load.
Feb 18, 2010 | Hotpoint WMA74 Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series heavy duty washing machine
Kenmore
remove edge decore trims from left and right side front of control panel
remove phillips screws from bottom corners of contol panel
remove knob from water level selector
raise control panel ~1 inch then flip over backwords on pivots
depress lock tab on righ/underside of water level control body where it touches metal mount plate
rotate water level control body 90deg anticolckwise
pull body off
top side of body next to knob shaft is 1/8 hex head bolt
turn clockwise to rais water level
anticlockwise to lower water level
machine can be operated with this part not fitted so can check level. fill, adjust screw, fill will start again, adjust screw, until water level is correct
reinstall in reverse order
Mar 01, 2008 | Kenmore 22422 Top Load Washer
Water level
Advisable that you open your inlet pipe fully to the machine. You could also check if the inlet filters are blocked, clean.
Mar 23, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool GHW9100L Front Load Washer Logo
1,855 people viewed this question
Dan Webster
Dan Webster
Sal De
