Question about Kenmore 15864/15862 Top Load Washer
Kenmore/works on one cycle only
I have a kenmore series 80 washing machine. It works only on the heavy duty cycle. On the other cycle's right before its about to start you can hear clicking noises. Can anyone help me with this probelm?
  • Kathy Monihan Aug 07, 2006
    thanks for responding! Being that it has burn marks, am I in danger of a fire starting?
    New Friend:
  • 163 Answers
That machine have somes burn contacts on the timer replace with a new one and that is...good luck
Posted on Aug 07, 2006
  • hector delacruz Aug 08, 2006
    not you are not but disconet it and call a tech to replace it...good luck
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Kenmore washers, heavy duty 80 series, no spin
Hello, Your problem is going to be with your lid switch, this is located normally either in the control panel or about half way down on the right side under the lid. This is a safety feature to stop you opening the lid while the machine is in a high spin. Once you have located the switch trace the wires back to the wire harness in the control panel. Disconnect the lid switch from the wire harness and with an ohms meter check for condinuity on pin 1 & 3 (the 2 outside pins not the middle this is a ground) You should find you have no condinuity and should replace this switch. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series draining problem
Check the following before replacing the timer.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Jun 01, 2009 | Kenmore Washing Machines
Rinse cycle do not disengaged
does it drain?did you check the lid switch?
May 17, 2009 | Kenmore Washing Machines
Kenmore 80 Series Heavy Duty washing machine suddenly will not drain. Tried different settings, nothing.
Unplug washer for 10 min to reset curcuit board. Then select the spin cycle. Selecting too many cycles in a short period of time can confuse the little brain in the board.
Apr 30, 2009 | Washing Machines
Kenmore series 80 washer only works on heavy duty cycle.
bad transmission,,check voltage...below 110 with load and water pressure switch or hose defective..
Dec 24, 2008 | Kenmore 24902 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 80 washer only works right on hevy duty load
CHECK SEE IF MOTOR IS SEIZED BY TIPPING MACHINE FORWARD AND SEE IF YOU CAN TURN THE MOTOR BY HAND. IF MOTOR TURNS FREELY , YOU HAVE A START CAPACITOR PROBLEM.
FXIT
Nov 20, 2007 | Kenmore 22422 Top Load Washer
Kenmore 15864/15862 Top Load Washer Logo
157 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
