Question about Frigidaire Refrigerators
GE PDS22SBPALSS FRIDGE NOT WORKING BUT FREEZER IS
BOTTOM FREEZER WORKS BUT TOP RIFRIDGERATOR DOESNT
eagle338
  • 4889 Answers
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Posted on Oct 09, 2007
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
SOURCE: Hey my ge profile top fridge bottom freezer is broken
I had the same problem, It turned out to be a bad circuit board ($350). Also check to make sure you don't have frost/ice build up in the rear of the freezer. The fridge draws cool air from the freezer through a vent in the freezer.
Posted on Feb 10, 2009
mastatech
  • 478 Answers
SOURCE: freezer works and fridge on top doesn't
Check behind the back wall for frost build up if the is a defrost problem this is the first sign
Posted on Mar 14, 2009
SOURCE: Water interior of fridge....GE profile 21.6 cubic ft. model #TBX22PIYMRBB
i have this problem .whats the fix
Posted on May 29, 2009
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | GE Refrigerators
Freezer Temp is to low. How do I reset it? GE Profile Model # PDS22SBPALSS
How do you Know it is too low? Is it frosting up? If so look for an air leak (follow the frost). If you are using a Professional thermometer and it is reading different than what the unit says it is, then you might have a sensor or board issue.
Apr 14, 2011 | GE Profile Stainless Bottom-Freezer...
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
BOTTOM FREEZER WORKS GOOD ,BUT TOP REFRIGERATOR PART IS VERY WARM
defrosted around fan between freezer and fridge. works fine now
Mar 03, 2009 | GE GBS18KBM Bottom Freezer Refrigerator
Feb 04, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Fridge not cold, freezer on bottom works fine
you have defrost problem 1 timer defrostthermostart or heater
Jan 19, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Refrigerators Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
