PC Power supply model: P4 ATX-300 schematics diagram
tbirdfan1
  • 3051 Answers
SOURCE: Power Supply Bestec ATX-300-12EB3- Rev: s4(S) 300-watts
yes if you can get the side plates unscrewed and the backplate plate uncrewed then the sides should lift off of the power supply now if you look at the board where all of the wires are it should be on the side by the power cord they are pretty small and some of them are soldered in so be carefull ok keep me posted ook best regards mike
Posted on Aug 26, 2008
freetek
  • 5568 Answers
SOURCE: schematic diagram for ATX-250-12E
Once upon a time . . . I actually repaired PC supplies but only for some oddball PCs whose makers were too stupid to buy 'off-the-shelf' supplies from others.
There is a good possibility that replacement parts to repair one of these will cost more than a new replacement supply. You just cannot compete with people who earn a couple of dollars a day assembling them.
They aren't tough to repair if you have some technical skills but it just isn't worth it.
I'm pasting part of a post below I just did for someone else who wanted to know if the board could be damaged from a failing supply-
"Since there have been some changes in available outputs and connectors even on ATX supplies, make sure you compare pictures of the supply to your own but in any case, I would recommend using a replacment rated at 350W as this will run more conservatively and not be as stressed as the 250 you now have. It won't cost a lot more and will not consume any more power but the critical components will run cooler.
Not as a recommendation, just a current example on eBay:
http://cgi.ebay.com/Mustang-Switching-Power-Supply-350W-Model-LC-B350ATX_W0QQitemZ250294363195QQcmdZViewItem?hash=item250294363195&_trkparms=72:1156|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
 The last couple I bought were $5 each with $7 shipping charge from a US source."
Posted on Sep 19, 2008
SOURCE: i need datasheet for AT2005 IC
one reference indicated AT2005 is the same as WT7520. I think WT7520 datasheet has some errors, but have found no one to ask about them. I need schematic of Powork PW-600, using WT7520; and a better WT7520 datasheet.
Posted on Mar 08, 2009
rulds2008
  • 3866 Answers
SOURCE: no voltage output
Would recommend replacing this unit instead of serrviceing it yourself it will cause adverse effect and may even smoke. These units once they dye there gone. If you need a diagram I would direct you to www.apex.com.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Apr 22, 2009
  • 733 Answers
SOURCE: My power supply is blinking green light and my PC has no power
plug your pc directly to your wall outlet and see if it turns on. If it works, then the problem is your power supply. If power supply has a reset button, press it and try again. If pc does not turn on when plugged to wall outlet, then power supply for pc may be out.
Posted on Feb 16, 2010
What is the value of R61 resistor
It's not worth enough to warrant you risking your life to replace it. Especially on that piece of garbage PSU. You can die if you try fixing a power supply and touch the wrong thing inside. Seriously.
Jun 11, 2012 | SPARKLE Computer Sparkle ATX-300GT 300W P4...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
Feb 16, 2010 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
Can an ATX-300-12E be used in place of an
I think it wont be a problem as long as both pwoer supplies are of same type e.g both supplies are for P4 sytems
Feb 11, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
SCHEMATIK DIAGRAM FOR POWER SUPPLI
I would also have liked to have had a schematic diagram for my ECHOSTAR 450w ATX power supply.
Not having one though, I have replaced two capacitors (one with a bulging top) and another with a leaking top, three rectifiers (two shorted and the third had a cracked case), and have ordered transistor Q1 (also shorted). Will also need to repair trace damage on the bottom of the circuit board. Other components check out OK so I hope it will be working again after the transistor arrives Monday. I need the -5v this one supplies to get my old computer running so I can retrieve last year's tax info.
Jan 17, 2010 | Echo Star 450W 450 Watts ATX Power Supply,...
Power supply packed i n
Yes, you can safely put in equal or higher. Just make sure it is an ATX and that it is P4 compatible. Most new ones all meet to those specs. Higher is actually better. I would go with a 400w or higher.
Apr 07, 2009 | Intel Allied 450W Dual Fan Pentium 4 ATX...
I need datasheet for AT2005 IC
Datasheet here:
http://www.china-ate.com/PDF/IC/AT2005B.pdf
Jan 30, 2009 | OEM Systems ATX P4 350 Watts Power Supply...
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
