Question about Drills
I have an old Bosch CSB420-E electric drill. I want to remove the key chuck. There is no screw in the chuck, so have no idea what to do. Grateful for any suggestions. Thanks
    Genius:
  • 1,212 Answers
You have to secure the armature or gear assembly that the chuck is attached to and rotate it counter clockwise to remove from the shaft. Warming it to 150 degrees F should make it slightly easier to turn.
Posted on Feb 18, 2012
3 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: drill chuck removal
The screw should be left hand thread and the chuck is normal thread. The 'workshop' way to remove the chuck is to remove the screw (done). If the jaws are still working then clamp a sturdy allen key in it and whack it against a workbench to unscrew the chuck. If holding the drill in the normal position you would stand with the workbench to your left and whack it down on that. If the jaws aren't working then you can grip the body in a vice and use large pipe grips or stiltsons on the chuck. Also check to see if the chuck spindle will accept a thin spanner to hold it, as this is a slightly more caring way to brace the spindle. Then you can can hold the spanner in the vice and use the allen key in the chuck and unscrew it that way.
Posted on Oct 25, 2008
rowdy45176
  • 2176 Answers
SOURCE: chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Posted on Jun 27, 2009
Bought a Bosch Drill. Chuck packed up after five months. Mega Mica Eastgate say chuck not covered?? Bought 2015/12/19 08:57:22 for R2999.00
not much can be done if the dealer will not warrant the chuck
if the bosch name appears on the chuck, call bosch direct and make a complaint but if it doesn't then get a new and better quality chuck and replace the chuck on the drill
remember that ordinary key operated 3 jaw chucks are not designed to used in a hammer operation continuously as that damages the screw mechanism of the chuck especially if the drill bit is over 5/16 drill size
if that is your operation, invest in a special masonry drill such as ramset or hilti or other makes of that sort
May 30, 2016 | Bosch Drills
How to remove keyless chuck
open the chuck jaws right up
down the center of the chuck you will see either a philips screw head or a hex head for allen key
hold the shaft at the base of the chuck to stop it from turning and undo the screw in the chuck in a right hand direction ( it is a left hand thread) when you have that out , still holding the shaft turn the chuck in the left hand direction ( normal thread ) and screw the chuck off
to assist in undoing the chuck do it up so that the jaws come out a bit
place something between the 3 jaws to act as a lever or use an allen key in the chuck done it tight and use that as a lever to undo the chuck
the secret is the lh thread screw in side the chuck which stops it from undoing when the drill is in reverse
Nov 17, 2015 | Bosch 18V Brute Tough Drill with Blue Core...
My new bosch cordless drill chuck doesn,t have a screw in it how do i remove the chuck ?
Dear Fred,
Please go to Replacement Parts in the link provided below. Too replace and remove your drill chuck on a cordless drill.
How to Remove Drill Chuck
Fare Well
Feb 07, 2015 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Oct 12, 2013 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
How to release the chuck on a Bosch GSB 16 RE
Open up the chuck jaws as far as they will go. At the bottom you will see a Phillips headed screw. This is a left handed screw and will require you to do it up to in fact undo it. After that undo the chuck as it taking of a nut. Place the chuck key in position and hit hard with a hammer in the undo direction and the chuck should spin off . It is already broken so don't worry about breaking it further. Remember to re[lace the screw in the new chuck or the chuck will unscrew for you in the reverse direction.
May 03, 2012 | Drills
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
Electric motor
You need an adaptor which would attach to the motor shaft (with a set screw) and provide threads onto which you can screw the chuck. I have never bought one of these, but possibly an internet search would yield a scource for such an adaptor.
Apr 29, 2009 | Bosch 1/2" 6.5 Amp High Speed Drill With...
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Mar 31, 2009 | Bosch 33618 - 2G Factory - Reconditioned...
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Drills Logo
136 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
