Question about Teac PD-D2410 5-Disc CD Changer
Commercially pressed CD's not recognised
I have an intermmitent problem where I load up the carousel with five CD's and often the player will only recognise that two or three CD's are installed. I have been careful only to use commercially manufactured pre-recorded CD's (i.e not burned CD's) and have ensured that the disks are unscratched and clean.
    President:
  • 3,130 Answers
Have you tryed to clean the les yet? Try to use a lens cleaning disc. If that does'nt help them you may need to take off the top and very carefully clean the lens very lightly with a cotton swab and a little alcohol. If that doesnt help the sevo alighnments might be off alighnment and unless you have special equipment and tools your not going to be able to do this your self BUT a repair shop might also make it cost prohibitive.. You may if the cleaning doesnt work is go shopping for a new player. Good Luck
Posted on Aug 07, 2006
I have a sony 400 cd player and the lights come on, but the carousel won't move. When I press any button the button will light up but nothing happens. The blue light flashes all the time. Also, the door...
sounds like your loading mechanism is jammed up. I would take the cover off, and look in the back where the cd's load to play and see if you can see anything out of place.
Dec 04, 2013 | Sony CDP-CX400 400-Disc CD Changer
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
I have a Wurlitzer 1015 OMT 50-Disc model. Is it possible to upgrade it to handle 100 discs? Thank you. Steve W.
It is possible.
If it is a 100 cd carousel then it is a simple computer setting.
If it is a 50 cd carousel you need a credit computer able to recognise 100 selections, a 100 slot carousel and a latch bracket for a 100 cd carousel.
I have never done it but it is definitely possible.
Jan 05, 2010 | Wurlitzer Jukebox CD Player
Have Sony cdp-c535 cd player. The door won't stay in. Keeps cycling in and out.
I had the same problem with our 5-CD Sony carousel player CDP-C535 (manufactured Nov 1993). I removed the top metal cover, and loaded five audio CDs into the carousel. After I closed the table, I pressed the carousel tight so that it stayed close, and hit the play button. The CD player tried to push the carousel out with quite a force. I needed to warp me fingers around the front panel to keep the carousel closed. After a few cycles of forcing the carousel to remain close, and caused two separate strong "clucks" from the gear area, the CD carousel became operational again. The diagnosis of gear problem seems right.
Nov 28, 2009 | Sony Audio Players & Recorders
Broken carouself? Can't properly open, close, rotate, etc.
Broken gears. The current replacement 5 disc is a CD/DVD player and sells for $129.00 at Sony or any other Sony retailer. The cost to have a service center even estimate the repair would be more than 50% of the replacement cost. Hope this helps
Nov 19, 2009 | Sony CDP-C265 CD Player
Power cord for Techniques SL-PD9 CD Player
Fairly common cable - I have several for various chargers for cameras, camcorders and laptops. You can get them at Radio Shack
Feb 01, 2009 | Technics SL-PD9 5-Disc CD Changer
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
Teac PD-D2410 5-Disc CD Changer Logo
90 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
