Question about The First Years 3-in-1 Booster Seat
Howdo the straps attach to the seat - The First Years 3-in-1 Booster Seat
How do I adust the seat back to make it not flop around
install an anchor behind the seat or install two of them, located equi-distant from the seat location on both sides but behind. The strap loops on the seat are for nylon straps with buckles. Attach to seat and attach straps in rear to anchors. You'll need pop-rivet tool to attach the anchors and if your seat is decent quality, it should have straps sewn-into it on the edges. Be sure to use a good seat-back with an area of padding to sit yourself onto. Life gets uncomfortable without a padded seat bottom!
Jul 28, 2014 | Old Town Canoe Old Town Trip 10 Angler...
What does cosco scenera model 22216-llp
You should see a harness strap over each shoulder that goes though the shell, behind the seat, and connects to a metal splitter plate.
The front of the harnesses (2) extend down though the buckle tongues then into the hip area of the seat.
There is a crotch strap that comes out of the shell where the child\'s crotch is. The buckle is attached to this strap.
There will be a LATCH (Lower Anchors and Tethers for Children) strap that goes through one of two belt paths. If used, this strap must go though the proper belt path.
Finally, there is a top tether strap the comes from the back of the seat - near the top - that will attach to the tether anchor in your car (see your car owner\'s manual)
My suggestion to you is to purchase a new seat. The protection of your child is most important.
Jul 10, 2014 | Baby Gear
Crouch strap
Hi
Please contact Graco for assistance with correct use of the harness
Get news from Graco delivered right to you inbox
May 10, 2014 | Graco Nautilus 3-in 1 Car Seat
In need the instructions
This is a seat post mounted bag, with attachments for the rails (2) on the bottom of the seatpost.
1. The straps going over the top of the bag will have to come apart. Removing them from the loop they pass through before re-attaching with the velcro.
2. Undo the straps and then feed them over the metal seat rails.
3. Re-assemble the straps in the same manner they were before and loosely attach the velcro. You will later tighten up the tension on these straps to snug the bag up under the seat.
4. Attach the velcro strap on the posterior of the bag to the seatpost.
5. Now the bag should be supported by the seat post strap and the seat rail straps (2). Hanging loosely and oddly from the seat area.
6. Tighten/snug the straps from step three, so the bag is drawn up against the bottom of the seat. Try adjusting all the straps on the bag until the bag appears to sit well under the seat.
7. DONE
Jan 05, 2013 | Avenir Bigmouth Seat Bag
Straps to be attached to back of 3 in one 2009 model. Where do you fasten straps on the back of the seat?
you need to provide more information (type of car seat, model of car) for an accurate answer, however:
most (if not all) car seats made these days have a ******** either side with a clip like this on the end (http://www.babysafetycarseat.info/wp-content/uploads/Car%20Seat%20Latch.jpg) which attaches to two hooks located between the seat cushion and the back cushion (http://autostol.info/wp-content/uploads/2010/08/Isofix-voorbeeld-11.jpg).
simply attach the clips to hooks, put your weight on the car seat while pulling the straps tight, and you're done.
Feb 28, 2011 | Baby Gear
Hello, Have used Nania Newfix Solo child seat very satisfacorily for 3 years with harness. Now time to remove harness (leaving back of Childseat in place). Have removed harness as per instructions -...
Right,
After several months of struggle to find written instructions how to attach the central harness adjustment strap (The one with metal anchor at the end) to the red clip (buckle) strap as seems to be shown in instructions. budyn71.jpg
I have found number to temtex uk company that supplies nania products to argos on 01162844910, while emailing them on sales@teamtexuk.com had no result. There's no need to attach the two. Central harness adjuster strap has to be detached and pulled by it's front end as far as it goes. budyn71_0.jpg
While red clip strap threads through the gap between backrest and the base. budyn71_1.jpg
And red clip strap threads through hole (bracket) at the back of the base. budyn71_2.jpg
Sep 26, 2010 | Nania Solo Combination
Cannot figure out how to attach straps to back of car seat
Car straps to attach to car of the straps on the car seat?
If it's to attach to the car, feel in the back seats where they join together (seat to backrest area) and you should feel some hooks in there.
Sep 18, 2009 | Safety 1st Summit Booster Car Seat -...
How do I attach the pump to the bottom of the seat with the velcro strap?
The velcro strap runs under the air bladder of the seat for the final attachment. The bladder needs to be empty to do this. Once the strap is in place, the pump can be used to fill the bladder.
May 13, 2009 | Topeak Allay by Nomad 1.1 Bicycle Seat
Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
May 08, 2009 | Graco Nautilus 3-in 1 Car Seat
The First Years 3-in-1 Booster Seat Logo
Top The First Years Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a The First Years Baby Gear Expert? Answer questions, earn points and help others
